Old 06-13-2013, 05:41 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default Master/Booster Advise!
I need to replace my leaky master and was going to go with Detroit Speed master/booster 9" dual or a wilwood master with a 8" dual booster. Is one better then the other or would they both perform well.
I have baer 6p Front and Rear with a 11" single booster. Im getting 12 lbs of vacuum, Detroit Speed said that thats what the 70 camaro test car has and brakes work fine.
Would love some feed back,
WicKeD
Old 06-14-2013, 01:31 PM
Apogee Apogee is offline
Given that your vacuum level is 12 inches Hg (at idle I assume), I would go for the bigger booster between the two options you listed, no question. The dual-9" booster should generate about 25% more boost than the dual-8"...30% more than the single-11".
Tobin
KORE3
www.kore3.com
Old 06-14-2013, 04:50 PM
WicKeD_SS's Avatar
Tobin
KORE3
Thanks for the advise! Do you know if the wilwood master will fit and work with the 1964-79 9" dual Booster ? and what size bore would be best for baer 6 piston front and rear?
WicKeD
Old 06-16-2013, 11:38 AM
I assume you're referring to the 1968-1976 C3 dual-9" unit? If so, then the Wilwood MC's should be compatible as they have slotted mounting holes compatible with a 3.25" to 3.40" stud spacing and the standard GM mid-size car register diameter. As for bore size, that should be a function of booster size/configuration, vacuum level, effective caliper piston area, pedal ratio and pad compound...however a ballpark bore size should be 15/16" to 1" for your application.
Tobin
KORE3
www.kore3.com
Old 06-16-2013, 02:52 PM
WicKeD_SS's Avatar
Tobin
KORE3
Here is the link to what I was thinking about buying http://www.ebay.com.au/itm/121002726...84.m1423.l2649
I did do a search of the one you listed and found one so If this ebay one will not work ill just order that other one. I did send wilwood a email with this ebay link to see if the MC will work so I hope to hear from them very soon. Thanks Tobin for your help!
-Brian
WicKeD
