Closed Thread
Old 07-19-2013, 01:12 PM
Ron in SoCal's Avatar
Originally Posted by Ron Sutton View Post
I understand. I am a visual learner as well. Especially for things as complex as women.
Here is a lil' sumthin' to tide everyone over for now.
Nothing better than a hot woman welding. Her roll center is.....umm, nevermind.
Ron in SoCal
69 Camaro in progress
  #1332
Old 07-19-2013, 01:17 PM
FETorino's Avatar
FETorino FETorino is offline
Here's a concept that may be hard for some to comprehend........I've been driving ol' Norwood everyday since Wednesday of last week.
Back to Ferd's and KPI...........
The off idle stumble and mid transition lean spot don't bother you?
I wish those were my current problems.
Just about perfect?
I'd guess that because I have a lot of experience with a little older model chassis with nearly identical specs, just a longer wheelbase.
Rob in SoCal
  #1333
Old 07-19-2013, 01:45 PM
Sieg's Avatar
Sieg Sieg is offline
Schmooth baby, schmooth.......
I am concerned about my front end geometry.......because of actual tire wear as opposed to hypothetical.
  #1334
Old 07-19-2013, 01:47 PM
Sieg's Avatar
Hmmm, that looks too hot, what's the amperage and wire feed set at?
  #1335
Old 07-19-2013, 02:00 PM
Ron Sutton's Avatar
I dunno. She set the welder.
I was helping the photographer.
Ron Sutton Race Technology
  #1336
Old 07-19-2013, 02:05 PM
FETorino's Avatar
I'm surprised you've seen that much wear going back and fourth to PetCo.
Now I'm coonfused What welder? I don't see a welder.
Rob in SoCal
  #1337
Old 07-19-2013, 02:34 PM
carbuff's Avatar
carbuff carbuff is online now
In a similar vein to the TW / WB ratio question, at what point would having a wider front TW compared to the rear TW start to decrease handling performance? Or stated a different way, is there such thing as too much front TW compared to the rear?
I don't think that was answered already, but my brain is a little distracted by things other than FErds and suspension in this thread.
  #1338
Old 07-19-2013, 02:37 PM
Sieg's Avatar
That confirms the heat setting.
Now I'm confused What welder? I don't see a welder.
Your problem is obviously too much stick-out.
  #1339
Old 07-19-2013, 02:47 PM
Ron Sutton's Avatar
g. Any parts of steering geometry: KPI, Caster, Caster Gain, Camber, Camber gain, Ackerman, toe, etc.
Since I believe I have a low amount of scrub in seeking a KPI/Castor split to gain grip on those tiny 285s I have up front is it more advantageous to simply gain castor by changing my UCA or would a spindle with a lower KPI angle be a better route. I realize the smaller angle of the spindle would create more scrub but since I have a high inside offset I would still be in what you consider the "low" range.
Tiny 285's
In my experience, keeping the KPI you have to keep the scrub radius lower is by far the smarter route. It's a little like widening the track width ... in that you're affecting the handling at the source, versus "trying to deal with it" afterwards with suspension tuning.
Same with scrub radius. If the car has a larger scrub radius, you will do a lot of tuning "trying to deal with it" afterwards with suspension changes. So no, I wouldn't change spindles, I would change or modify your UCA and/or LCA to achieve more caster.
Once I know the actual scrub radius ... and the "for sure" KPI of your spindle ... I can give you two caster targets. One that would "ok" for most road course corners ... and one that would turn on a dime regardless of corner radius.
Since we have been given 3 KPI different numbers on the C6 spindle ... until we're "sure" of the KPI ... and scrub radius ... it's hard to say anything with certainty. I can teach you a "car guy" way of determining your scrub radius ... if you want to measure scrub radius yourself.
  #1340
Old 07-19-2013, 03:00 PM
Ron Sutton's Avatar
k. The difference between being "involved" or "committed'"
I'm involved in building a car.
Gae should be committed.
JerDog is involved in some trash talk.
Dave is committed to change.
GW is involved with INTORS.
I am committed to Formula43
Ron in So Cal is committed to wheels.
99.9999999999% on the forum are involved with a Camaro.
I am committed to a Torino.
I choose the path of the pig since I am committed to whooping some involved chickens.
Rob, I'd better clue everyone else in on our joke.
Rob & I were talking about the handling of his Torino ... and I asked him, "Are you 'committed' to making your Torino handle optimum ... or just 'involved'?
Rob said, "I'm not sure of the difference between the two."
I said, "Well ... this morning when you had ham & eggs for breakfast ... the chicken was involved ... but that damn pig was committed!"
Closed Thread
