Old 08-11-2013, 10:46 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by Ripped View Post
AND to cap it all off and celebrate a successful weekend, I decided the FRY the palm of my hand on a nice hot engine component.
I can only dream of burning my hand on a hot engine part.
Congratulations you have that problem.
Rob in SoCal
Old 08-12-2013, 12:37 AM
Thanks, and yeah it does sound nasty.
I didn't think it was possible for this car to get even more attention, but with this motor, she does.
Anyhow, I've been working my @ss off trying to get some of the kinks out.
AND yes the car has been fighting me every step of the way! ...still
FINALLY after hitting a real low point this morning, I made some real progress tonight.
Just a few of the issues;
-A melted alternator cable (don't ask)
-I turfed the brand new (brand name not mentioned) spark plug cables, because at least one insulator was split right apart on the distributor cap - which explains the frequent misfire. Reinstalled my good old MSD dizzy cables, which work great.
-Fixed the cobra oval air filter, which was interfering with the float adjustment on the back of the quckfuel carb, and then the lid, which wasn't going tight, due to another interference issue.
-Revamped the ground wires to the optima battery
and a myriad of other minor issues.
I'd like to be out cruising around tonight, to check things out further, but I'm not sure about holding the shifter, in the fried palm of my hand.
Maybe a beer in a chilled glass and bad television, is in order, tonight.
and I hope I am finally over a hurdle here LOL
Ahhh the fun is just beginning.
Old 08-12-2013, 07:27 AM
Ron in SoCal's Avatar
Congrats on a successful weekend!
Ron in SoCal
69 Camaro in progress
Old 08-12-2013, 09:47 AM
It looks and sounds awesome!!
Old 08-12-2013, 11:19 AM
fleetus macmullitz's Avatar
Congrats on the progress...sweet lookin' and soundin' FErd.
Old 08-13-2013, 08:31 PM
Ripped's Avatar
Ripped Ripped is offline
Well if I was nearby, I'd gladly drop by and help speed up the progress!
Hope you're rolling soon!
Yeah... I know... I know LOL
Thanks, and hoping to keep having more. Next is the tuning.
Thanks a lot!!
Thanks kindly
Alas... I picked up a whole bunch of electrical supplies, ready to solve all my battery and grounding problems.
Yes checked the resistance on the alternator case, so I thought with an aluminum block, that I would run a dedicated ground to the alternator to the chassis. The resistance was a little higher.
While making up the cables, I noted that the heat shrink was damaged on the starter cable.
Hmmm, what would cause this?
I mega insulated the new #4 gauge alternator wire from possible abrasion.
Then I looked at the steering linkage and drag link.
Hmmm when I do a hard right turn... that linkage would come close to the Positive cables.
So, after rewiring everything, I did a hard right turn... and yes very close to the wires.
Clearly the wires were hanging down and contacting the drag link, on a hard right turn. Right near the inner tie rod end.
S..T I was shorting the battery with every hard right turn!
Yep I thought back, first time I melted the battery I was backing up doing a hard over. Each other time, I was backing into the garage, yes... doing a hard right turn.
So I adjusted all the cables, made them clear the steering easily in all configurations. Added lots of protection, a few zip ties and clamps.
Just the clocking of the new starter puts the cables down low near the drag link.
One problem solved. Next trying to tune the carb.
Old 08-24-2013, 07:42 AM
Ripped's Avatar
This week, I completed the rewiring and relocation of the starter wires (soleniod and 12v) The soleniod wire and connector were a little fried.
Fixed the oil flter adaptor. The billet piece Brent gave me with teh engine is real nice, but the oil filter smashes against the sway bar.
On the previous incarnation of the engine I had the stock adaptor taken to a machine shop. He milled the adaptor on an angle, and then faced all the bolt faces on the same angle.
The filter is 1/2" clear of the sway bar, in the worst case scenario.
I spent a little time polishing all the Ford blue paint off of the adaptor, to match the aluminum engine, and popped it on.
Some more parts coming this weekend, including another power valve and air/fuel gauge
The drivers door has developed this really bad rattle in the window.
It doesn't help that the engine shakes the car so much
Little bit of rain this weekend.
Tires have brutal traction in the rain
Old 08-26-2013, 10:44 PM
Ripped's Avatar
The test and tune continues.
I dropped in the 10.5 power valve, adjusted the timing. Better again, almost civilized. Civilized but deafening inside
Seriously you need ear plugs to drive this thing.
Next on the agenda, is the failing power steering pump. Bearings are going, so it's making hideous noises, and the pulley is sliding in and out at least 1/2"
I have the air fuel gauge now, just have to make a revised console panel, to hold it, then hook it up.
Existing gauge layout;
The start button is going to be axed.
I'm thinking switches at the bottom (across) and the four gauges side by side in a quad layout at the top 2/3 of the panel.
Next I worked on installing the new emblems.
Some fitting work, but that's done.
Now I have to decide on orientation.
To the side (side facing)
or to the front.
The problem with the side, is that the emblems are a little hard to see, with the shock towers canted towards the inside. It might encourage people to lean in over the car a little too far?
Old 08-28-2013, 10:40 PM
Ripped's Avatar
Replaced the power steering pump tonight.
In keeping with the tradition of the car, it was a %$#@% battle, but it's in. Pulley alignment is great, no squealing and pump and steering feel good.
Why should anything be easy?
Old 08-28-2013, 11:59 PM
I like them pointing to the sides. I wouldn't be concerned with people leaning over too far.
Keep truckin!
