Old 10-14-2013, 01:36 PM
Rod P's Avatar
Rod P Rod P is offline
end of season Racing is coming and I have been getting the car ready, with some cool parts, and a new set of tires came in! Falkens 615ks 275-40-17s all four corners! just makes me feel the car will be hooked up
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 10-14-2013, 06:33 PM
Rod P's Avatar
finished installing the anvil header panel i did have to ream the side mounting holes along with the grill mount holes
I used a unibit! and the girlfriends pink cordless
and I left a carbon line on the backside of the header panel
Rod Prouty
Bangshift Stories
Old 10-14-2013, 06:40 PM
glassman's Avatar
glassman glassman is offline
Is that the breastcancer awareness cordless?
Pm me.....Mike
Old 10-14-2013, 06:51 PM
Rod P's Avatar
Mike
now that you mention it! it is save the Tata's month!
Rod Prouty
Bangshift Stories
Old 10-14-2013, 09:22 PM
you get your rubber on?
Old 10-14-2013, 09:59 PM
Rod P's Avatar
not yet, I have a few more practice days and then at the start of November, NEW SHOES! ready for the last 3 events
Rod Prouty
Bangshift Stories
Old 10-19-2013, 06:45 AM
sixnina's Avatar
sixnina sixnina is offline
You changed up sizes? When I saw her last you were running the 245/40r17 all around right?? Did your suspension changes allow you more room for rubber?
Shane
Old 10-19-2013, 09:45 AM
Rod P's Avatar
Shane
I had 245 on the front and did some short testing on some prototype parts to run larger rims, and then I switched to the ridetech tru-turn kit up front when a few friends of mine David, Mary, and Crosby all said I really must run the kit, so I installed the kit and did alot of testing(i know Ridetech tested it) but I don't have a mini tub car so the balance for my 275/40/17 on all four corners is slightly different then ridetechs 48 hour Camaro, so I ended up with 800lbs springs on the front 225lbs springs rear, and my rear sway bar rate is.........wait I cant give away all my secrets
Rod Prouty
Bangshift Stories
Old 10-19-2013, 12:51 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Nice tires! Will you be taking them to Scottsdale and Del Mar in November? It's been a while since you've made it down this way.
Old 10-19-2013, 12:57 PM
Rod P's Avatar
yep Matt! I will be in Scottsdale and visiting you guys in socal for Del Mar, I wanted to come out and cheer you on at Optima, but I will be racing Pleastanton that same weekend you guys will be at Optima, so I was bummed about the conflicting weekend events
Rod Prouty
Bangshift Stories
