Old 10-26-2013, 03:06 AM
paulk68 paulk68 is offline
Default stock camaro subframe
when using a stock camaro subframe I have read alot of people say to weld it up to wake it stronger. I assume this means the seam running down the middle of the rails but what other areas are people welding? does anyone have pictures of a before and after?
thanks
Old 10-26-2013, 09:39 AM
You will have to look at your frame and see where the factory missed. Its pretty clear...well you can see through that is.
Old 10-27-2013, 05:49 PM
David Pozzi's Avatar
You need to keep the heat down & skip around or you will warp the subframe. I've heard some horror stories. The frame overlap area can hide oil & mess up weld quality.
http://www.PozziRacing.com
Old 10-28-2013, 04:14 AM
Thank you for the great info
Old 10-28-2013, 10:04 AM
Sieg's Avatar
Sieg Sieg is offline
In case you don't have these:
I have a spare subframe that needs a little adjusting due to left front wheel side impact. Spec's aren't too far off but it still needs to see the frame chiropractor.
My debate is: Which is correct? Straighten, blast and weld or blast, weld and straighten?
Old 11-01-2013, 06:06 PM
pist0lpete pist0lpete is offline
I would straighten first. Adding more welds will add stiffness that was not there during the impact. That will make it more difficult to return to factory specs and could cause some undesirable side effects after pulling.
Old 11-12-2013, 10:01 PM
jovozx12's Avatar
jovozx12 jovozx12 is offline
That's a very nice frame schematic. I'm assuming that all the first gens are exactly the same right? I know they all interchange.
Old 11-12-2013, 11:39 PM
there are a few subtle differences. 67's are closed off inside of the bumper mounts, bump stop in on the frame too.
Old 11-13-2013, 07:03 AM
jovozx12's Avatar
Measurements are still the same right?
Old 11-13-2013, 08:50 AM
BMR Sales's Avatar
Seig, Blast, Straighten & Weld! By Blasting 1st, you can see if there are Cracks. You might need to Break & Cut, then Straighten, then Weld it up. This is what I've done using a Celette Bench!
T.C.
