Closed Thread
Old 11-24-2013, 07:30 PM
Sieg's Avatar
Sieg Sieg is offline
Looking good! Definitely like the setup. I'll assume there enough forward/aft adjustment to comfortably modulate the throttle under braking?
Rob Box FTW!
  #1702
Old 11-24-2013, 08:33 PM
Wissing72's Avatar
Wissing72 Wissing72 is offline
Spent 20 min with cardboard making a test fit pedalbox template.
That's new.
I don't think the cat likes the "go" pedal......
Chris
70 Chevelle. Roadster Shop Chassis, The shop llc/ Jon Lind interior LS3/6speed. Thanks to Precision Classics and Collision Eugene, Or. http://precision-classics.com/
Build thread:https://lateral-g.net/forums/showthread.php4?t=39517
  #1703
Old 11-24-2013, 08:42 PM
carbuff's Avatar
carbuff carbuff is offline
Nice photobomb!
So you will hopefully get a laugh out of this, but... I'm starting a new design project at work. In my field, we use some kind of theme when we name our projects. My company founder is from Detroit, so he thought a car-based theme would be fun, and I decided we'd go with old musclecar names. We recently changed the plan for the project to go away from a minimalist approach to one that is a bit more, shall I say, "maximalist". So it seemed like a perfect choice to use "Torino" as my first project name in the famliy!
I spend entirely too much time on this site apparently...
  #1704
Old 11-24-2013, 08:49 PM
carbuff's Avatar
Are you going to use the linkage and bellcrank from the picture above? Looks pretty slick, but I'm curious how you will mount it all if so...
  #1705
Old 11-24-2013, 09:06 PM
FETorino's Avatar
FETorino FETorino is offline
Rob Box FTW!
Between the brake and throttle pedals there are too many adjustments. It's funny how you take something like pedals for granted until you have to start from ground zero in setting them up.
The Joes pedal is pretty slick. It has adjustable stops in both directions and a garage door spring to snap it back. Of course the carb side of the equation will also get a Joes return spring setup.
He does seem to take issue with it for some reason. Both him and Flash.
Nice photobomb!
Well you succeeded
Bryan
Yes I am planning on using the bellcrank assembly. I will have a full cage and an underdash bar so the bellcrank will likely mount to a flange on the underdash bar.
Rob in SoCal
  #1706
Old 11-24-2013, 09:43 PM
We'll you certainly aren't going to be running out of real estate... So mount away there big boy! Ya got enough room in there to run a similar crank and whistles and knobs set up as used by the wizard in The Wizard of OZ...
  #1707
Old 11-24-2013, 09:51 PM
Spent 20 min with cardboard making a template
Maybe you should have spent 25.....
  #1708
Old 11-25-2013, 12:21 AM
Lenie's Avatar
Lenie Lenie is offline
It's all Torino and 360 some pounds of sideoiler. You either have one or aren't willing to admit you want one.
[/QUOTE]
Oddly enough the shakes are gone and I'm now feeling better!
Lenie
  #1709
Old 11-25-2013, 12:25 AM
Lenie's Avatar
That's new.
Appears you have a few holes in your game plan!
Lenie
  #1710
Old 11-25-2013, 04:10 AM
Lenie -- When building a car of this - er - um - "caliber"…. you need to save weight where you can...
Closed Thread
