Go Back   Lateral-g Forums > Technical Discussions > Safety Equipment
Old 03-31-2014, 12:32 PM
MX145 MX145 is offline
Haha! You guys are awesome!
Old 03-31-2014, 05:28 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Finally got it all buttoned up. After checking the rigidity of the panel with the backing plate welded in I opted to not install the secondary strap to the rocker. It may be gambling but I don't think so. My guess is an impact hard enough to tear this new mount lose would be fatal. I it starts haunting me it will happen.
All in all I'm pretty confident and satisfied with the results.
Looks great Seig.
Even if you put in a 4-point roll bar, and 5 point belt system later on... you can still use the 3-point belt set up on the street. I find that with my 5-point belt system I don't use the shoulder harnesses on the street all the time... just the lap belt.
Nice work
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 03-31-2014, 06:13 PM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by DaleTx View Post
Looks great Seig.
Nice work
Thanks Dale. I knew all along that I'd only use a 5 point for "special occasions" and end up using the belt only if I didn't have two systems.
Hopefully I'll come across a deal on roll bar and sub-frame connectors components in the near future.
Old 04-01-2014, 07:40 AM
rickpaw rickpaw is offline
Nice work on the belts. Very detailed write up and pictures.
Summit has DSE roll bar in stock with free shipping (to a freight terminal). That will save you at least $100 there. I'm ready to pull the trigger on that, as soon as some of my extra parts get sold.
Tu Ho
Old 04-01-2014, 08:11 AM
Sieg's Avatar
Thanks for the heads up Tu. DSE is what I'm leaning towards, like you, a few things need to get sold first!
