Old 07-22-2014, 09:18 AM
n77nxc's Avatar
n77nxc n77nxc is offline
Default 67 Camaro Brake Setup Question - Disc/Disc
My project is moving along, and I'm currently working on the brake system.
Here is my setup.
CPP Big Brake kit (Corvette 13" disc) with sealed bearing hubs
CPP Wilwood 2 piston rear disc kit
Brand new stainless steel hard lines
My question is what brake booster/master cylinder/proportioning valve setup I should use.
The car came with a similar setup to this:
The stamping on the proportioning valve is PV4 which should be disc disc.
I want to purchase a new setup. What do you guys recommend?
I'm just looking for a simple setup that will work well with the modern disc brakes.
TIA
1967 Camaro - Project "Resale Red" - Sold to 175RGR
Old 07-22-2014, 10:30 AM
IndyNova's Avatar
IndyNova IndyNova is offline
I'm using a wilwood proportioning valve and master cylinder, manual brakes
https://facebook.com/Protour69Nova
69 Nova-Ridetech, LS
Old 07-22-2014, 11:54 AM
n77nxc's Avatar
Tobin, at Kore3, just sold me the same setup.
Old 07-23-2014, 09:22 AM
rickpaw rickpaw is offline
You may also want to look into 9" dual diaphram booster as well. The 9" will give you more clearance around the engine.
Tu Ho
Old 07-23-2014, 09:24 AM
n77nxc's Avatar
I'm not going to run a booster at first and see if I like it.
Old 07-23-2014, 12:07 PM
Just pick the right master and you'll be good.
Old 07-23-2014, 12:15 PM
n77nxc's Avatar
Tobin advised a 7/8" Bore Wilwood MC will do the trick, based on my setup. I opted for the Wilwood rear proportioning valve also.
Here are the part numbers for reference:
Master: WIL-260-9439-BK
Prop Valve: WIL-260-13190
This is the setup:
Old 07-23-2014, 12:55 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
This is the setup:
That'll do the trick!
Curtis
Old 07-24-2014, 10:18 AM
Thats a pretty set up ain't it?! I use it on all my builds now.
261-13270 is the full kit number for 1.120 bore. BK for black or P for ball milled silver.
Old 07-24-2014, 01:19 PM
n77nxc's Avatar
Looks is secondary to function when it comes to this. I will say that I don't mind losing the sight of the booster in the engine bay.
