Old 09-22-2014, 07:52 PM
Sanchez Garage Sanchez Garage is offline
Default Need help with spc upper arms
I have spc upper a arms, ats stock height, stock lower arms. I purchased this some years ago. My issues from the pics is the upper arms are resting on the frame. My hours don't allow me to call marcus and just wondering if anyone here can help. I switch the upper ball joint to a tall to see if that would help which it did not. These are on. 71 chevelle.
Old 09-22-2014, 11:37 PM
normal if you are on jack stands. ie: not resting with the weight of the car on the tires.
Old 09-23-2014, 04:19 AM
It's on the ground no jack stands
Old 09-23-2014, 04:22 AM
You can use an airline cable (carefully routed) or get a shorter stroke shock.
Old 09-23-2014, 04:26 AM
dhutton dhutton is offline
Looks like a bare frame. You need the car fully assembled and at ride height before worrying about this. As it sits now the springs are not compressed under their normal load.
What springs did you use?
Old 09-23-2014, 04:27 AM
I think we were posting at almost the same time. If its allready on the ground and thats ride height, you may have to notch the frame to make that work. I have a similar set up but they are not that close to the frame at ride height.
Old 09-23-2014, 04:29 AM
It may be my lower arms that help make it work.
https://lateral-g.net/forums/show...&highlight=581
Old 09-23-2014, 04:32 AM
100%. Car has to be at ride height before its an issue.
Old 09-23-2014, 04:45 AM
nicks67ca nicks67ca is offline
I also believe the cross shaft is flipped. It looks like the the offset where the arm bolts to the cross shaft needs to be flipped. The slight offset should give you more clearance to the frame.
Old 09-23-2014, 04:17 PM
sorry, meant with weight on the suspension. suspension at mid travel. That upper ball joint should be higher than that.
