Old 11-17-2014, 01:06 PM
Revved's Avatar
Revved Revved is offline
Default Good source for stainless tubing in different radii?
What is the best source for buying stainless steel tubing for building headers that sells different radius bends?
I'm starting into this Ice Engine Works header modeling kit and will need tubing soon. I'll post up pics when it looks like more than a pile of Legos
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
Old 11-17-2014, 02:41 PM
mach1stang's Avatar
mach1stang mach1stang is offline
Burns stainless is who I use. They're pricey but the quality is bar none!
Kody Willis
1969 mustang fastback - Lots of secret surprises to keep under wraps.
2012 boss 302 - BMR lower control arms, relocation brackets and pan hard bar, cortex racing coilovers, enkei 18x10.5's front and rear with 315/30/18's, offroad x pipe, lethal performance over axel pipes, SLP loudmouths.
"Your boss's exhaust when you floor it sounds like Jesus stepped on a lego in the middle of the night while going to the bathroom!"
Old 11-18-2014, 10:48 AM
Evan Iroc-Z Evan Iroc-Z is offline
I have used http://www.mandrel-bends.com/catalog/, however I am on a lot tighter budget than most here.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 11-19-2014, 10:46 AM
68RS350 68RS350 is offline
I have found Vibrant has some of the tightest bend radii on tubing. I bought a 1.75" OD with a 1.75" Bend radius.
Old 11-19-2014, 11:26 AM
Revved's Avatar
I use Vibrant tubing primarily for most of my fabrication projects but they don't offer their tubing in different radii. I'm building a set of headers using an Ice Engine Works kit and the blocks are made to match 3",4",6" radius tubing so I need to find a source that sells all.
Very cool stuff if you need to build custom headers and don't mind a little TIG work!
-Sean
Old 11-19-2014, 03:45 PM
mach1stang's Avatar
I wish ICE would come out with the 3" kit I contacted them about a while ago!
Kody Willis
Old 11-20-2014, 07:21 AM
Revved's Avatar
When I ordered my kit a few months back they said they were considering 3" 4" and 5" kits. I do a lot of 3" intercooler tubing and exhaust as well and would love a 3" kit
-Sean
Old 11-20-2014, 04:08 PM
mach1stang's Avatar
I've contacted them about a 3"-4"-5" kits for large turbo exhausts, and they said they were working on them and would possibly be releasing them soonish but tat was prolly a year or so ago.
Kody Willis
Old 11-20-2014, 05:41 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I have used these guys.
http://www.mandrelbendingsolutions.c...let/StoreFront
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 12-03-2014, 04:46 PM
Solid LT1 Solid LT1 is offline
Performance tube in So-Cal and Columbia Mandrel Bending in Oregon are 2 of the most cost effective suppliers of mild steel and 304 stainless steel mandrel bends, if I'm doing something weird.....Burns Stainless but, sit down when getting quote from Burns. If your doing a lot of stainless, you will want to learn about back purging your welds even Solar Flux wont get the job done, only proper back purging. Burns has some good articles on welding stainless, if you using 316 or 321 I hope your a skilled welder, that stuff isnt fun to weld.
