Old 02-18-2015, 03:08 PM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Default NEW! 69 Camaro Stamped Steel Gas Tank with Notched corners + Powder Coated! Mini-Tub
This is a brand new offering in the market! Perfect for those who don't want/need a Vaporworx Stainless setup.
Clear your Mini-Tubs and 3" Exhaust!
Please, don't mistake these as "close" to a Vaporworx setup, they are NOT, this is a stamped steel tank, built to accept an electric fuel pump and sending unit. Of course, there is a LARGE price difference, we are able to offer these with a Walbro Pump, Sending unit, Straps, Anti-Squeak and a Cap UNDER $600 FREE shipped in the 48 states! (Please PM or Call and let us know what motor/HP you are running so we can give you an accurate price as the pumps do vary in $)
This is a good tank, it will do the job just fine and we are able to ship it with one of several different Liter Per Hour Walbro USA made electric IN TANK fuel pumps depending on your fuel needs, a sending unit, straps, Anti-Squeak strap liners and a cap!
The Vitals:
This notched corner 69 Camaro and Firebird tank is perfect for mini-tub applications. The front of this tank is narrowed to 27" to clear up to a 345 tire and 3" exhaust. To help regain fuel capacity from the notched corners this tank is 1" deeper than stock. Even if you do not have a mini-tubbed car this tank will work on a stock car where you need a little more clearance for exhaust. Please note that this tank will not work with narrowed leaf spring kits.
- 1969 Chevy Camaro and Pontiac Firebird EFI Fuel Tank
- Fuel Injection Ready!
- Uses our GPA series fuel pumps, available in 5 sizes.
- Uses aftermarket 5-bolt senders. Multiple Ohm ranges available to work with factory or aftermarket gauges.
- EFI style internal baffling. Extra Large 4.3 liter internal fuel tray to prevent fuel pump starvation.
- Perfect for your Pro-Touring, Autocross or Road Racing Ride
- Fuel pump and sender are recessed in the tank for easy installation with no modification needed to your car.
- Looks like an OE tank when installed.
- Coated galvanized steel then Powder Coated Silver.
- 1" Deeper than stock
- Longer mounting straps included with the tank
- Size is: 39-3/8" x 20-7/8" x 8-3/4"
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 02-19-2015, 06:41 AM
clill's Avatar
clill clill is offline
Thumbs up
Another Stielow innovation goes into the mass market.
Old 02-20-2015, 10:17 AM
MCB Matt's Avatar
The 67-68 tank is in stock ready to ship as well.
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 02-27-2015, 04:01 AM
tigerhays's Avatar
tigerhays tigerhays is offline
Default curious
Just curious,and I may have over looked it,but how much fuel will it hold?
Old 02-27-2015, 07:08 AM
MCB Matt's Avatar
The capacity is the same as the stock tank. They added a little depth to it to regain full capacity.
Matt
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 03-07-2015, 05:52 PM
Sonar Chief's Avatar
Question
Interested to know if these would be acceptable for carb'd engines? Obviously the pressure is the main diff between EFI and carb .... can I get a pump installed for carb'd engine?
Thanks for keeping us in the loop.
Michael
Old 03-09-2015, 10:07 AM
MCB Matt's Avatar
Yes, the tank will work for a Carb'd motor with the use of the soon to come (hopefully in about a week or two) adapter plate that takes the place of the Gen5 or similar pump and allows the use of Walbro or similar drop in pumps.
Matt
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 03-12-2015, 02:32 AM
steery's Avatar
steery steery is offline
If only these had of been made available about a month earlier. I'd have been all over one.
Old 03-12-2015, 08:33 PM
snichols28 snichols28 is offline
Got mine in a quickly manner. Thanks again Matt!
Old 03-13-2015, 09:40 AM
MCB Matt's Avatar
We appreciate the business!
Happy Friday!
Matt
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
