Old 10-16-2014, 08:23 PM
Track Junky's Avatar
I think the mid plate is a good choice on this one. From the looks of that motor I don't feel the 4 bolts alone on that front plate will hold over a long period of time.
Gaetano Cosentino
Old 10-16-2014, 08:43 PM
dstryr dstryr is offline
Plus he has access to all the machines and tooling he wants...just time ?
Dennis
www.creationsultd.com
1969 Chevelle Build - Meanstreets Performance Style
https://lateral-g.net/forums/showthread.php4?t=39456
Old 10-17-2014, 12:27 AM
358Mustang 358Mustang is offline
Originally Posted by Chassisworks View Post
This is a cool project! I wouldn't stress too much about getting a chassis fixture as long as your work surface is flat and level. We have sold thousands of chassis kits that were built in garages around the world. Just keep measuring three times and weld once.
Regarding the engine mounting, if you have a front plate you definitely need to run a mid plate. It's going to reduce binding, increase safety, and increase chassis rigidity. Also, you should run a torque limiter. This will keep you from cracking the tranny case, or the billet front plate.
You weld the stub coming off the rod-end to the frame rail then the other end bolts to the engine mount boss.
Thanks for the input! I didnt build a full mid plate, but I made some "wings" that bolt to the bell housing...
I think they will be more than suffiecent. They mount off two of the 7/16" bolts and I also made them so that they will take a .500 dowel pin and they will piggy back onto the bores that locate the bellhousing to the engine.
My thoughts too.. I think what I've got should work pretty good now.
I know... Too bad I have to keep production running so I dont have time to make things like I want. But that is what you are for....
I have some spindle pins I need machined.....
More billet goodies.
I've got to yard the motor out so I can build the mounts off the frame for the "mid plate" . What a pain, my garage is stuffed full!!
Old 03-17-2015, 09:23 PM
How's this one coming along?
Old 01-20-2018, 10:54 PM
DBasher's Avatar
DBasher DBasher is offline
What he said, I’d love to see some progress on this one.
Old 09-15-2020, 11:39 AM
Forgot about this place... Haha
Well I ended up building another car starting about 2018, the old track coupe is sitting in the corner of a shop collecting dust with the front end still cut off..
Finally got this engine together as of early 2020 and on the dyno, that was a big feat for me. Had a few issues , but nothing related to the engine .. Had a modified set of dyno headers that broke on multiple pulls so we had to pull those off and weld them up. The electric water pump wasnt sealing to the old yates belt drive so I had to rig up some spacers to sandwhich in place, and then the dry sump tank was puking a bunch of oil. Luckily I brought mine (which was a proper baffled tank) and that fixed the issue. The scavenge in the dyno tank has no sort of baffle or anything where it exits back into the tank so it must have just been making a tornado of oil going back into there with the 5 stage pump.. All in all that was a fun (stressful) day..
The aim with this car was to clean up a lot of fab work that I did on my last car (which started out as a project when I was 17 and no idea what I was doing, other than the fact that I had welders / plasma cutters near by ) , as well as keep it "street" legal
Rear end is a typical 3 link setup w/ panhard.
Front end I designed and built based off a cortex radial spindle.
Decided to go full standalone EFI sort of last minute, so I have been spending a lot of time (and cash ) trying to get that wired up and going.. This car will be running by the end of the year!!
The Following 2 Users Say Thank You to 358Mustang For This Useful Post:
DBasher (12-07-2022), WILWAXU (09-15-2020)
  #47
Old 09-15-2020, 11:42 AM
Sorry the pics are huge, Im a noob
Old 09-15-2020, 12:42 PM
Couple more. Decided to go DBW to compliment the ECU and its capabilities. using a unit from EFI hardware (uses a bosch DBW unit encased in a nice aluminum housing) The long term plan will be a 6 speed air shifted sequential but that is a little pricey so for now the 4 speed is going in. Plan on using a strain gage in the shifter for flat upshifts.
The Following User Says Thank You to 358Mustang For This Useful Post:
camcojb (09-15-2020)
  #49
Old 09-15-2020, 05:33 PM
Gitter dun! Thing is a bad ass!
The Following 2 Users Say Thank You to Flash68 For This Useful Post:
358Mustang (09-17-2020), camcojb (09-15-2020)
  #50
Old 09-17-2020, 01:57 PM
carbuff's Avatar
carbuff carbuff is offline
I like that DBW setup. Does the 'kit' you mentioned include a bracket or did you fab that yourself? Have you confirmed it runs through the full range of motion? Not that I've looked at many of those, but I like how this setup is done. Good job.
