Old 05-25-2015, 12:56 PM
Mac&Otto Mac&Otto is offline
Originally Posted by Matt.A View Post
Should make for a real fun car, in general.
Hey Matt. Your car is fantastic. I keep checking in to see progress. Will we see you in scottsdale in November?
Cal
Old 05-25-2015, 02:02 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Cal
It's possible. If I have any energy left after SEMA, I'll try and make it out to Scottsdale. Will you and Paul both be out out there driving?
Old 05-25-2015, 02:33 PM
We will both be there but not sure who will drive. Paul won the muscle machine of the year finalist in March and the car has to be displayed in a specific spot for the show. Not sure yet if you can autocross and show as well. I would like to see Paul drive because he's finally having fun and making progress in the car. I will be the pit crew.
Cal
Old 05-26-2015, 11:03 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Beautiful work on this car.....keep the updates coming!
Old 05-26-2015, 11:18 AM
Swain's Avatar
Swain Swain is offline
Nice updates are awesome. Got me motivated again
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 06-27-2015, 11:57 PM
Default A little more progress.
Well, I managed to get a little more time this weekend to work on my car. I installed new door latches and strikers, installed my new Hurst super shifter built by David West, took final dimensions on my driveline and installed the front runner on my motor. Everything worked out fairly good accept the balancer, I have to order a new one as it doesn't line up with the Corvette front runner. Outside of that, it doesn't look like much but it was progress.
Old 06-28-2015, 12:02 AM
Default Super Shifter
I had David West build me a complete shifter assembly. I went with a Super Shifter and I'm glad I did. He put together the shifter, mounting bracket, linkage and pre assembles it on another trans for you. Ready to bolt on when you get it. It's a flawless piece and as he said, fit perfectly when I got it.
Old 06-28-2015, 12:05 AM
Default Mast 416
One of my more favorite tasks this weekend. I assembled the front runner and started getting familiar with my Mast harness.
Old 06-28-2015, 12:12 AM
I also received and started bolting up my clutch, pressure and flywheel. I used Modern Driveline out of Idaho and they are extremely knowledgable and helpful. I used a superior Kevlar clutch, chromoly flywheel, pressure plate and tilton hydraulic bearing and master. The service was fantastic and I suggest talking to them if your in the market. I measured up the driveline and will send the info to them on Monday.
Old 06-28-2015, 12:17 AM
Default Final fab
I'm moving the car next week to build a skeleton to mount the nose, radiator, etc. on. I will take it to my friend Forest Fincher and we will use our bender to build the mounting skeleton for the nose, rebuild the bay bars to miss the booster and tidy up a couple small fab items. Then it is tear it down and start body and paint. I can feel it.
Thanks, Cal
