Old 06-10-2015, 01:23 PM
Payton King's Avatar
Boxing out the top link
Old 06-10-2015, 01:26 PM
...and finally, the mini'est of mini tubs
Old 06-10-2015, 01:31 PM
Pin height was too high by .125 so the piston was too low in the block and we did not want to change rods.
Old 06-10-2015, 02:05 PM
syborg tt's Avatar
It's seriously starting to look like a race car.
marty-mj
Old 06-10-2015, 02:13 PM
Panteracer's Avatar
Default Thrift shop camero
You could always line bore the crank up
That's what happened to my Pontiac
then all you need to do is:
Find the shortest timing chain ever
cut the dizzy so it will go all the way down in the block
cut the starter so it will align with the flywheel
Just being a smartass... I hate when things are
off by just a little
Cool build.. can't wait to see it finished
Bob
Old 06-10-2015, 03:17 PM
I was thinking USCA car.
Old 06-10-2015, 07:32 PM
Nice to see some more progress, Payton. Thanks for sharing.
Old 06-10-2015, 07:44 PM
Big deal.... those are the same seats in my Miata....
LOL
Old 06-10-2015, 07:54 PM
Build-It-Break-it's Avatar
Wow! Your car is looking killer! If I wasn't so stuck on keeping the rear seats I would of done the same set up.
Ahmad B
Old 06-11-2015, 06:30 AM
Graham08's Avatar
Graham08 Graham08 is offline
Thanks for the update! This project is too cool! I dig the Watt's linkage adjuster. I thought the one I made for my sprint car was trick...it uses a track bar mount from a NASCAR left truck arm to adjust in 1/4" increments.
It's sort of funny seeing the rusty tin that's left up against brand new tube.
Nice work!
