Old 08-31-2015, 11:51 AM
awr68's Avatar
awr68 awr68 is offline
Default Which Paint Gun to Buy?
I have a few cheap guns that I have used over the years. They are of the $40 range. I'm ready to step up and get a new gun for base/clear but don't want to spend $1k as I'm not a pro painter. I see that Eastwood sells a Concourse Pro for a fair price. I have an 80 gallon air compressor that I use.
Your thoughts and expert advise?
Tony
'68 Camaro
Old 08-31-2015, 01:06 PM
67camaro496 67camaro496 is offline
How much are you willing to spend?
Old 08-31-2015, 01:10 PM
awr68's Avatar
Just starting to look at what's out there. Does $300 get you a good enough tool? $500?
Tony
'68 Camaro
Old 08-31-2015, 02:57 PM
http://www.ebay.com/itm/Devilbiss-TE.../390763946971?
Here is a good quality gun. It really depends on how many times you are going to use it ect. i like the tekna
http://www.ebay.com/itm/2-Devilbiss-...-/390830447889
here is a setup that will allow you to shoot base/clear and primer with the different size fluid nozzles.
it is really about gun adjustment and like anything else experience. if you do not paint alot i would not spend 500-600 dollars for a gun. go to refinishnetwork.com. that is a good site that will be able to help you pick out a gun.
Old 08-31-2015, 03:30 PM
awr68's Avatar
Thanks for the info! I will look into it!
Tony
'68 Camaro
Old 08-31-2015, 04:05 PM
analyte's Avatar
analyte analyte is offline
If possible, try the gun out before you buy. They all feel a little different so make sure you get something you like that's comfortable to use. I prefer Sata, but there are a lot of good guns out there.
Kerry
Old 08-31-2015, 05:49 PM
dhutton dhutton is offline
I have an Iwata LPH-400 HVLP and a Satajet RP Digital. The Sata is like painting with a firehose. I would not recommend it for what you are looking to do. The Iwata puts material on more slowly and I recommend you watch for one on eBay. There can be some good deals. The nice thing is you can resell it for most of what you paid for it.
Old 08-31-2015, 06:28 PM
Musclerodz's Avatar
try to find you a used iwata lph-400
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-31-2015, 09:17 PM
awr68's Avatar
Thanks guys! I knew you would send me in the right direction!
Tony
'68 Camaro
