Old 12-21-2015, 12:44 PM
paulk68 paulk68 is offline
Default Baer Brake bracket on ridetech spindle
Anyone have a picture of a baer brake bracket mounted to a ridetech spindle with true turn what to make sure i use the correct hardware. ridetech included 2 bolts but I am not sure what to use for the second mounting holes?
Old 12-28-2015, 10:25 AM
so the baer kit came with a 3' and 2.75" bolt for the braket. as you can see the 2.75" bolt is going to hit the posi link when I turn. is it safe to run a 2" bolt on this braket? i will keep the 3" at the tie rod end
Old 12-30-2015, 02:47 PM
so I am running the 2" bolts with nylock nuts torqued to 85 ft lb's per baer instructions. My question is are these long enought, this is how it looks torqued down should I look to run a little bit longer bolts? this is what holds the caliper bracket to the spindle. thanks
Old 01-13-2016, 03:32 PM
Apogee Apogee is offline
Ideally, you should have at least 2-3 threads sticking through the locknut, so I would think that a 1/4" longer fastener in that application would be in order.
Tobin
KORE3
www.kore3.com
Old 01-13-2016, 04:55 PM
SlowProgress's Avatar
I can get a photo tonight.
Old 01-14-2016, 12:27 AM
I just realized I put non-locking nuts on for all the fit-up work. Once I put a tall self-locking nut on there it will probably look the same. I think I will just buy a shorter all-metal locknut when I do the final install. I agree that good practice is to have 1.5 - 2 threads past the locking feature.
Old 01-14-2016, 03:53 AM
Thanks Guys, I will go up on my bolt size and check to make sure it does not interfere with the posi link.
Old 01-14-2016, 08:01 AM
98ssnova's Avatar
98ssnova 98ssnova is offline
2 thread is the magic number to ensure the locking feature of the nut is working or engaged. Those bolts look to short especially for a nylon lock.
Old 01-15-2016, 03:55 PM
So the shorter bolt was 2 inches this is a 2 1/4. much better getting through the nut but very close on full lock. a 2 1/8 would be perfect i think. anyone know someone that make custom bolts?
Old 01-16-2016, 12:10 AM
You won't need a customer bolt here. There are several styles of all-metal locknuts that are shorter than the nylon insert style that came with the kit. If you cut the bolt down it will rust where you are missing the plating. I would just go to the local hardware store and find a shorter locknut.
