Old 03-03-2016, 01:04 PM
frankv11's Avatar
frankv11 frankv11 is offline
I bet those brake lines are a pain . Even though it looks so easy.
Car is looking great
Old 03-03-2016, 02:32 PM
Nice work on the brake lines, Will.
Old 03-03-2016, 03:16 PM
Thanks and yes it has been a pain. I've been getting lucky so far with the bends, but the flares have been killing me. So much so that i tend to leave a little "room" for a "re-try" and when it works first time it makes the line a little more difficult to install.
I should have some more pictures soon of the progress lately.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 03-07-2016, 07:54 AM
Well I was making my run through lines and a friend came and mixed it all up.
Previously I had the lines as above and added in the line for the rear.
In my head this was "ok" but wasn't ideal for how I was wanting the lines to look. Nine Ball made a suggestion for how to route them and i'm happy he did!
I decided to "free hand" the bends on some scrap tubing to see how it would look.
He was right, it looked MUCH better. Decided I was going to bite the bullet and risk running short on stainless to re-do those lines.
All three lines are in place there, clutch still needs to be bent and terminated for the hydraulics there.
I also finished up the cross piece for the front brakes and used my nice stainless brake clamps I got.
Finished up the bends on the rear line to get it closer to the floor and where I could secure it to the frame/floor.
Since I ditched about 2-3ft of tubing, I did come up shorter than I had hoped. Ended up about 6-12" shorter than I was originally looking for, so I just bought a slightly longer flex line (due in wednesday)
Overall, I'm pretty happy for my first time doing this. Could I do it better? Probably. Maybe this will be re-visited someday...but i doubt it (unless there is an issue).
With that finished, it's time to start looking to install the engine/transmission back in the car. I wanted to trim the bellhousing so it didn't hang lower than the oil pan.
That took a bit to cut, but got it done and re-painted (no pics).
I also got some old parts blasted while at Nine Ball's place, so they're ready to be painted and be put back on the car (when the time is right).
First time taking this bad boy out of the box. Was happy to see the splines lined up (was nervous as I never confirmed it was the right clutch).
Was going to be making solid progress until I found....no flywheel bolts...
Always seems to be the case that when you get momentum something stops it. LSX didn't come with them (not surprised) and clutch didn't (not a huge surprise either as they typically are re-used from stock). I have a set of ARP bolts coming in tomorrow. Hoping to have this in before I leave for Mexico this weekend.
William
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 03-07-2016, 08:29 AM
Nice job on the brake/clutch lines they look good. At least you know waiting for the bolts is a worth while up grade over stock bolts. Very nice Will.
Old 03-07-2016, 08:33 AM
Very true. As I ran around on Sunday trying to find them, I was thinking "I'd rather use ARP since it will be holding the 1000+lb-ft..."
Prob happened this way for a reason...
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 03-08-2016, 08:45 AM
BigBronco's Avatar
BigBronco BigBronco is offline
Looking forward to wiring this thing up with you!
Get this thing fired up.
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
Old 03-08-2016, 09:59 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Great progress Will,car is looking great
Old 03-08-2016, 12:43 PM
vdshenoy vdshenoy is offline
Those lines look sexy!
Old 03-08-2016, 04:00 PM
sleepertime's Avatar
sleepertime sleepertime is offline
Post
The lines are looking great.
We're you able to get the various fittings in stainless, such as the 90° tube to brake line?
My build BRNAGN 1969 camaro SS
