Old 04-29-2016, 02:31 PM
Nine Ball Nine Ball is offline
Spark plug wires and routing:
Engine bay is completed, except for the custom intake tube I have to build. Then wiring the entire car.
Finished out the entire rear brake lines. Had to build a couple aluminum brackets, since the ones on my car were missing. I saved $45 in repro brackets, and ended up with some nice aluminum ones instead
For floorpan:
For top of 12-bolt axle:
Used DSE's braided steel flex line kit on top of the axle:
Used the SUR&R lines, and added stone guard spring for the entire rear lines.
Here is my remaining list to do, as of a week ago. Already knocked a few of the items out:
Tony
Founder, LS1Tech.com
1969 Camaro SS Convertible | 1970 Chevelle SS 454 | 2006 Viper Coupe | 2014 Viper TA | 2014 Camaro SS 1LE
Online Garage: www.fquick.com/NineBall
Old 04-29-2016, 04:07 PM
gofastwclass gofastwclass is offline
Looking excellent! I love how deceptively simple everything appears in the engine bay.
The list idea is always good, I've done that for years. I discovered it helps me stay focused on the tasks that matter and / or their sequence. For me I prefer to tape a copy to the car so I can cross things off as I complete them or add things as I encounter problems.
Old 04-29-2016, 06:13 PM
I have it taped to my beer fridge, right next to the car. So, if I feel I worked hard, I reward myself with a beer and crossing something out.
Old 04-30-2016, 03:13 AM
paulk68 paulk68 is offline
man I love seeing the updates on this. I am using a lot of similar parts so this has been extremely helpful. Looks great.
Old 04-30-2016, 07:07 AM
glassman's Avatar
glassman glassman is offline
Very nice write up Tony!!! Thanx for taking the time to show us these details....
Great build, tasteful, well executed.
Enjoy in good health
Mike
Old 04-30-2016, 06:10 PM
Zoomin Zoomin is offline
X2 on the details, really is helpful.
Where did you get those brass 90* fittings for the rear brakes, and the spring wrap?
1964 Lemans
1966 Skylark
1969 Camaro
Old 05-01-2016, 06:55 AM
My bulkhead connectors at that 90 are NPT threaded. So, I used these:
http://www.speedwaymotors.com/90-Deg...ing,28392.html
Gravel Guard Spring is part# RSD-GGS316S-20 on Summit Racing
Tony
Old 05-01-2016, 02:58 PM
69lsvert 69lsvert is offline
Thanks so much for the detailed pics and all the great info.
Old 05-01-2016, 08:22 PM
Tony
Thanks Tony, much appreciated.
Will the gravel guard install over the flare?
1964 Lemans
1966 Skylark
1969 Camaro
Old 08-18-2016, 05:09 AM
dhutton dhutton is offline
Did you get the convertible top installed? I am trying to decide if I should minitub my 69 convertible.
