Old 08-28-2016, 03:06 PM
simon455's Avatar
simon455 simon455 is offline
Default Speedtech a arms and shockwaves first gen Camaro
Has anyone did speedtech uppers and lowers with Ridetech shockwave using "t" bars as attachment to lower control arms? Any issues?
69 drag radial firebird (sold)
72 pro touring gran torino (dad's)
68 camaro ss pro touring pending project
2002 dallara ir-2
c5 rag top with z06 stuff
300 tire custom night rod
2014 viper TA
Old 08-29-2016, 08:03 PM
jimmythehand jimmythehand is offline
I just installed speed tech upper and lowers with ride tech coilovers with t-bar on my 68. instructions say that you can install t-bar above or below lower, but i talked to speed tech guys about that and they recommend above. No real issues at all. Hope that helps.
Old 08-29-2016, 08:27 PM
simon455's Avatar
That's how exactly I was analyzing it, above...
Thanks for your input.
2002 dallara ir-2
2014 viper TA
Old 08-30-2016, 07:21 AM
Blake Foster's Avatar
On a stock subframe?
you will have to trim the coil spring bucket. also for the best install you would use our Chicane upper bracket, this will reduce or eliminate any side loading of the shock shaft and probably make them last longer.
Blake Foster
www.speedtechperformance.com
Old 08-30-2016, 08:59 AM
simon455's Avatar
stock frame, aware of the spring pocket trimming. When You guys sell the chicane kit, is the shock assembly used with that kit actually longer than the one used in coil over kit for such as ridetech or qa1 that mounts into
stock spring pocket? or its just the top shock mount is changed?
2002 dallara ir-2
2014 viper TA
Old 08-30-2016, 11:56 AM
here is a link to the install instructions http://www.speedtechperformance.com/...69_Camaro2.pdf
I would suggest installing the brackets and control arms and then measuring the shock length, but yes it will be aprox 1" longer
Blake Foster
