Old 02-22-2017, 10:47 AM
Bonebuster29 Bonebuster29 is offline
Default Hand brake install on gen1 firebird camaro nova
Just curious if anybody has install pics of how they did their hand brake conversion and what they used parts wise for the install.
I am thinking about buying a Lokar hand brake but I've heard just as much good as I have bad about their product.
Fyi i am using Wilwood Aero6 up front & Aero 4 in the rear
68 Firebird - Build still in progress
DSE Speed kit 3, Glink rear, Moser 12bolt, LS3 540hp, T-56 Mag, Willwood Areo brakes...
Old 02-22-2017, 04:27 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
thats the same set up I used and the ford explorer e brake cable kits works with your setup,I liked the Lokar products
Old 02-22-2017, 05:43 PM
Z06vette's Avatar
Z06vette Z06vette is offline
My 67 camaro had one installed when I bought it (abandoned project, no drivetrain), but when it came time to install the driveshaft and the car set at ride height, no way it would work. The linkage on the lokar brake hung down into the tunnel. It was not even close to clearing the driveshaft- like several several inches too low. So I removed it. I'm sure there are other options. Just something to thing about/work around.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 02-23-2017, 08:38 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
http://www.ironworksspeedandkustom.c...prod/prd25.htm
Old 02-23-2017, 09:23 AM
Originally Posted by CamaroAJ View Post
I've seen that, looks like it could be very useful.However, I'm more so looking to see how people mounted it, if they used consoles, and how the ran the cables under the car.
Old 02-27-2017, 07:46 PM
rebob's Avatar
rebob rebob is offline
I made one for my 63 Nova. The lever is from an older BMW and the cables are from helmar, very good selection and low prices. I bought long cables because I wasn't sure of the length, ended up cutting them and crimped a new stop on at the brake end. Just 2 piston Willwoods, works real good. The console goes all the way to the back seat. Don't really have any pics from underneath?
Rick
http://www.helmarparts.com/Emergency...ables_s/64.htm
Old 02-28-2017, 10:40 AM
Rick
I was thinking of doing mine very similar and running it under my full length console, after seeing your I will for sure be doing it very similar. I like the ability to hide the cables and once its setup and working correctly there wont be a need to adjust it.
Thank you very much for the pics
