Old 02-26-2017, 08:28 PM
Panteracer's Avatar
Default Dreamin Ta's
Cut out almost all of the bad spots
in the trunk prepping for the new
Fuel cell. Fab time next
Bob
Old 02-27-2017, 09:19 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Looks great, Bob! You're making me want a Firebird even worse now...
Old 03-24-2017, 01:55 PM
Panteracer's Avatar
So the ridetech 4 link is almost done
Decided to ditch the rear seats as they
weigh 20.5lbs and will more than likely place
the battery in the back seat area
Weight savings so far
SS tank vs alum 25.5lbs
rear deck lid 23lbs
fuel pump (new one is in tank) plus battery tray 14lbs-have alum box very light
rear seats 20.5lbs
Gives me 83 lbs savings so far and that is not counting
the insulation I removed under the seats and behind,
the rubber trunk liner (that thing was heavy)
old steel cut out of the trunk-doing alum panels and alum framing
Car started a few years back without a 5 point bar or subframe connectors
at 3710 now down to 3355 and betting less once I am done with fab etc
Trying for 3200lb range... 355 lbs off the car so far
Bob
Old 03-26-2017, 08:35 PM
Nice work, Bob!
Old 05-16-2017, 02:13 PM
Panteracer's Avatar
I finally got motivated and finished the Ridetech 4 link
installation..
Bob
Old 05-16-2017, 05:03 PM
fleetus macmullitz's Avatar
Looks good Bob.
Keep us 'Bird fans posted going forward.
Old 05-16-2017, 10:02 PM
glassman's Avatar
glassman glassman is offline
Sweet. What u crossin- with this summer? that? or that mid-engine thingy?
Mike
Old 05-17-2017, 09:06 AM
Panteracer's Avatar
Default Dreamin Tas
Mike,
Hoping to get the Firebird done before Goodguys
and then try to dial it in this summer.. the Mid engine
thingy is always the backup... will be at Crows for the
Park Memorial on the fourth of July weekend
I also may try to do Fresno SCCA events a few times
as they run 5 times in the morning and then tweak and
fun runs in the afternoon so 10 runs in a day help you
figure the changes you make on the car
Now trying to figure out how to fit the Sway bar as
it needs to be modified
Bob
Old 05-18-2017, 10:26 AM
Looks good, Bob. Would it be easier to reroute the exhaust instead of build a new sway bar?
Old 05-18-2017, 01:01 PM
Panteracer's Avatar
Default Dreamin Tas
Trey,
Yes I may reroute the exhaust but was hoping to deal with
that later.. tips are just a bolt on right now
Might have to just shorten the bar
Bob
