Old 12-18-2017, 07:03 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default Ridetech Chose MillerBuilt for its Full Floater Needs!
MillerBuilt is very proud to be a part of the all new 48hr Camaro build by Ridetech!
Follow along as this awesome car is assembled live at Barrett Jackson!
http://www.ridetech.com/info/2017/12...d-1971-camaro/
https://www.ridetech.com/info/2018/0...as-the-answer/
Old 08-12-2018, 10:31 AM
Default Get Yours
In Stock!
Old 08-12-2018, 02:06 PM
bret's Avatar
bret bret is offline
Supporting Vendor
I must say that this bolt on floater kit works perfectly. Ive not given it any thought whatsoever since it was initially installed on the Gen 2 48 Hour Camaro in January. 8,000 road miles and 5 sets of tires worth of autocross laps later, its still perfect. Nice work!
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
The Following User Says Thank You to bret For This Useful Post:
dontlifttoshift (08-12-2018)
  #54
Old 08-15-2019, 08:20 PM
Full Floater System -
Installs onto any Rear-End that utilizes "Early" or "New Style/Torino" Big Bearing Ford Ends.
That's right,,,, you can use your current rear-end housing, NO welding & simple installation. BOLT-ON!
Advantages:
  • Bolts to your Early OR New Style/Torino Big Ford Housing End (Chevy 10/12 bolt application now available! https://lateral-g.net/forums/showthread.php4?t=52854 )
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th/6th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th/6th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications will add 3/16″ per side to your existing wheel mount surface (based on an existing 2.50″ axle/brake offset)
Fitment: Any rear-end housings that utilizes Early or New Style/Torino Ends
Big Ford Bolt-On “Full Floater Kit” (pictured below)
E-brake Assemblies & E-brake Cable Brackets NOW INCLUDED With Each Floater Kit
Full Floater Kit Includes:
• (2) Billet Steel Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) SKF 33 Spline Hub Assemblies
• (2) E-brake Assemblies
• (2) E-brake Cable Brackets
• (1) Install Kit
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICING AT - https://millerbuiltusa.com/big-ford-base-kit/
Have interest?
Have questions?
Need more info?
Distributor Inquires Welcome!
Big Ford "Bolt-On" kit in action!
Old 08-18-2019, 05:16 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Got mine installed, but not on the road yet. Very nice piece I might add. Exceptional customer service too from Jay.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 02-11-2020, 12:51 PM
cwylie cwylie is offline
Is that upside down?
Old 02-14-2020, 07:41 AM
214Chevy's Avatar
I hope not. Currie built the rear end and I sent them the Miller Built kit as Jay said they've installed many of his kits. Can anyone else verify how this looks? Even if it is upside down, I still have to install the 3rd member, axles, etc. Plus, everything else is coming back off to get the chassis and rear end powder coated.
'68 C10 swb
'72 Chevelle
Old 02-14-2020, 11:06 AM
73camarols1 73camarols1 is offline
I didn’t notice it at first. But the parking brake mount is on top. I think usually it’s on the bottom under the axle. It should be easy to swap them from side to side. Just my thought Bill
Old 02-14-2020, 11:43 AM
214Chevy's Avatar
Yeah, I didn't notice it either until he mentioned it. Guess Currie got some dummies working there, huh? I mean, where's the quality control?
'68 C10 swb
'72 Chevelle
Old 02-14-2020, 01:33 PM
eville's Avatar
eville eville is offline
I’m not sure but I think you put it top or bottom to switch the direction of pull for park brake. I’m thinking it should work either way.
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
