Old 03-15-2018, 01:15 PM
FETorino's Avatar
FETorino FETorino is offline
Ron
For the engine mounting it’s obvious you are using a front motor plate but what about out back?
Are you going to run a mid plate and suspend that unobtanium sequential or is that the start of a rear rubber insulator mounting point the transmission tail is resting on?
How much longer till the wings arrives? I want to see the wing.
Thankfully I will get to see this standing still because it seems obvious I won’t get close enough to see it on track.
Rob in SoCal
Old 03-15-2018, 02:35 PM
Ron Sutton's Avatar
Hey One Eyed Rob !
Ron
Good question. You need to be careful with how you mount engines & transmissions ... or stuff breaks. When I see people who go by the rule of "when it doubt ... make it stout" on race cars ... that often doesn't work out. Mounting the engine & transmission is a good example of that. If we mount the front of the block with a motor plate, the back with a mid plate & the transmission with a solid or rigid mount ... the chassis flex will break the transmission case.
What I have found works well is mounting the front of the block with a motor plate ... hanging 1 or 2 straps from the firewall cage bar to "help support" the back of the engine/front of trans with no added rigidity ... and supporting the back of the trans with a poly mount. That is what will be done here. With LS, we use one steel strap at the mid point. One end bolts to the top bellhousing bolt& the other end bolts to a bracket welded onto the firewall bar. See illustration below.
Wing arrives next week. But I'm not posting photos of it just yet.
Well ... I could be bribed. If you buy the beer next time we're at Thunderhill.
LOL. It is going to be bad fast, compared to most. The cool thing is it will be confidence inspiring & comfortable to drive with all the tire, downforce & overall grip.
Give Greg a few weekends of track time to get used to it & he'll be damn fast.
Ron Sutton Race Technology
Old 03-15-2018, 03:10 PM
FETorino's Avatar
Originally Posted by Ron Sutton View Post
Hey One Eyed Rob !
Hey. I’m probably closer to One .75 Eyed Rob and climbing right now Ron
Thanks for the insight on the mounting. If you run a Front and mid plate on the motor what would you do with the transmission?
Ok. I’ll look for the wing pictures in my e-mail. You know I’ll buy you a Racer5 at the traditional Willow watering hole.
Greg is pretty good in the small tire yellow car so I’d bet you’re right, he should run well in TTU.
Rob in SoCal
The Following User Says Thank You to FETorino For This Useful Post:
Ron Sutton (03-15-2018)
  #74
Old 03-15-2018, 03:38 PM
Goosesdad's Avatar
Salivating.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
  #75
Old 03-15-2018, 04:14 PM
Ron Sutton's Avatar
If we run a rigid motor plate & mid plate, we "sit" the transmission on a rubber mount for support. No bolts.
Old 03-15-2018, 05:17 PM
DBasher's Avatar
DBasher DBasher is offline
[/COLOR]
Hell on wheels!
Thanks for sharing all of this, Ron.
Old 03-16-2018, 03:21 PM
Blake Foster's Avatar
yep that is how I have done it. Or like you said no mid plate then poly trans mount never solid trans mount
Blake Foster
www.speedtechperformance.com
Old 03-19-2018, 09:15 AM
FETorino's Avatar
I know those wing photos are about to get posted.
I showed you mine, let’s see yours.
Rob in SoCal
Old 03-19-2018, 05:14 PM
DBasher's Avatar
I’m ready.
Old 03-22-2018, 08:55 AM
DBasher's Avatar
Pull up a chair & grab some popcorn, because this is going to be a cool build in an amazing short time.
[/COLOR]
Is it done yet?
