Old 05-08-2018, 09:20 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default What are you using for + buss bar power junction? need some ideas please
What are Y'all using as a main power junction up front when the battery is in trunk? I'm planning on running O gauge cable to one and then send wires to starter, alternator from there looking for suggestions/pics of what you have used for this junction.
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 05-08-2018, 09:26 AM
dhutton dhutton is offline
Hi Rich I use these
https://www.ebay.com/itm/Speedway-Mo...ty!76233!US!-1
https://www.ebay.com/itm/Speedway-91...ty!76233!US!-1
https://www.ebay.com/itm/Junction-Bl...UAAOSwUdlWgakd
Edit: fixed first link
Old 05-08-2018, 09:41 AM
Musclerodz's Avatar
AAW 500009. Similar to the middle pic Dhutton posted a link to.
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-08-2018, 11:35 AM
ZMAN1969's Avatar
well maybe I'm not clear those are for going through the firewall - for that I'm going to use a HD grommet, what I'm looking for a a junction where I can connect several leads for starter, alternator fans like a buss bar of sorts
similar to this but with protective cover
LS6 6speed
1999 Firehawk
Old 05-08-2018, 11:53 AM
slimjim's Avatar
slimjim slimjim is offline
I'm looking at running this one.
for my setup I'm running a 1/0 gauge wire direct from the battery to the starter with the solenoid in the trunk. So it won't go near this terminal.
Then I'll be running a fused(or 80A circuit breaker) 8 gauge wire from the battery to one bolt on this terminal and either an 8 or 4 gauge from the other terminal bolt to the alternator. allowing a bunch of other fused power wires to be connected in-between.
And even though no-one will see it, my OCD will sleep good at night.
NC
streamline 68 camaro
Build Thread here
Old 05-08-2018, 01:23 PM
rickpaw rickpaw is offline
I'm using one exactly like the one in the ebay link below.
https://www.ebay.com/itm/Jump-Start-...tax4de&vxp=mtr
Has a battery jumper post, plus multiple + connections, and a cover too.
Tu Ho
Old 05-08-2018, 02:41 PM
I’m using the one in my third link. I’m simple minded so I try to keep things simple...
That combined with the bulkhead pass through in the first link gives me everything I need. Let’s me keep my Vintage Air connections inside the car.
Old 05-09-2018, 02:28 AM
rocketrod rocketrod is offline
I mounted a power distribution block, see first link, on the firewall near the master cylinder.
http://www.madelectrical.com/catalog/cn-1.shtml
I also added a power relay module nnear the the driver driver sidee radiator support that provided two fused 60A circuits, one for battery power and another for ignition power. I used to power the fans, A.C. relay, headlight relays, fuseblock, etc., etc.
https://www.waytekwire.com/item/4609...e-Module-60A-/
Rod
1969 Camaro - LS2/4L70E
Old 05-09-2018, 10:55 AM
gerno's Avatar
gerno gerno is offline
I went to West Marine and bought something like this for my grounds and positives for fans at the front on the engine bay. I then ran 2 10g wires to feed it. Only issue is its not covered for the positives but haven't had any issues.
https://www.westmarine.com/search?Ntt=buss
Old 05-10-2018, 03:43 AM
65 Drop Top 65 Drop Top is offline
Fused distribution block
