Old 05-09-2018, 03:24 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default ZR1 Calipers
Does anyone know if 2009 Corvette Brembo calipers will work with DSE subframe? Looking to use these with steel rotors .... 14". DSE says C-6 rotors will work with their subframe/spindles, but did not know if the Brembos were an exception??
Old 05-09-2018, 03:52 PM
dontlifttoshift's Avatar
If it bolts to a Corvette spindle, it bolts to the DSE spindle.
Donny
Old 05-10-2018, 06:09 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Yes you can bolt the caliper to the spindle. No you can not use steel rotors with ZR1 calipers as the offset and size is different than the carbon rotors. Unless someone makes specific swap rotors that I haven't come across yet.
The Following User Says Thank You to CamaroAJ For This Useful Post:
DKz Garage (05-10-2018)
Old 05-10-2018, 06:57 AM
I assumed OP knew that he needed magic rotors to work with those calipers. Here is a complete set on sale for $5,500. https://www.racingbrake.com/ZR1-Iron.../gm-irp-10.htm
If I'm spending that kind of money, I'm going RSRT StopTech.
Donny
Old 05-10-2018, 09:01 AM
DKz Garage's Avatar
I was thinking that i would have to use the carbon rotors.... just was not sure. Thanks for the input!
Old 05-12-2018, 05:08 PM
bmiller's Avatar
bmiller bmiller is offline
Racing brake and girodisc make steel rotors for zr1’s that are cheaper alternatives to ccm rotors
Brandon
71 El Camino
63 Nova
70 Buick GS
The Following User Says Thank You to bmiller For This Useful Post:
dhutton (05-13-2018)
