Old 10-06-2019, 07:32 AM
conester2013 conester2013 is offline
Default T-56 Magnum to LS3 - new input shaft?
So I was told by some buddies of mine that I can't just get a bell housing to mount my T-56 to my LS3, and that I will have to change out the trans input shaft because the one that is in it will either be too long or too short.....cant remember which. I haven't heard of anyone doing this. I thought I could just get a quicktime bell housing designed to mate the two up and be good. Can someone tell me if I will need to change the inout shaft?
Old 10-06-2019, 11:04 AM
randy randy is offline
Not only does a t56 magnum and ls3 go right together if you use an Fbody bellhousing and throughout bearing you won’t have to worry about shimming it. Exact setup that I have
Old 10-06-2019, 02:08 PM
A t56 viper box would need a new input shaft .. the t56 magnum was/is designed literally for these kind of swaps
Old 10-06-2019, 05:04 PM
Che70velle's Avatar
Yeah, depends on the T56. Early models not originally installed behind an LS engine require a new input shaft, front cover, and bell, which requires some setup work. Other T56 boxes, as Ryan said, require a different input shaft as well.
What T56 do you have?
Thanks Dad!!
Old 10-06-2019, 05:44 PM
I have a Tremec T-56 Magnum from American Powertrain that I got 4 years ago when I installed it behind my current 350 small block chevy.
Old 10-07-2019, 12:53 PM
samckitt's Avatar
samckitt samckitt is offline
Same here.
Scot
86 Monte SS
LS2/T56 Magnum
