Old 11-01-2019, 09:21 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by JD67SS View Post
Is Sled Alley doing the paint, or are you having Dutchboys shoot it?
JD
Still getting quotes
Stielow Engineering
Old 11-02-2019, 04:44 PM
Stielow's Avatar
Clears the hood!
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (11-03-2019), kwhizz (11-03-2019), NAPA 68 (11-02-2019), Sonar Chief (11-03-2019), waynieZ (12-09-2019)
  #73
Old 11-04-2019, 10:22 PM
JB400's Avatar
JB400 JB400 is offline
https://www.hemmings.com/auction/1969-chevrolet-camaro
The Following User Says Thank You to JB400 For This Useful Post:
kwhizz (11-06-2019)
  #74
Old 11-05-2019, 09:24 PM
randy randy is offline
Did you ever run a icebox or no real need? Also what front and rear spring rate have you been running ?
Old 11-05-2019, 11:13 PM
glassman's Avatar
glassman glassman is offline
Originally Posted by JB400 View Post
Great read, thanx for the link.
Mike
The Following User Says Thank You to glassman For This Useful Post:
JB400 (11-06-2019)
  #76
Old 11-06-2019, 05:30 AM
Stielow's Avatar
I run a big intercooler with no issues. Iceboxes are more of a drag race thing.
For rear spring rates I like 200 lb/inch with the DSE set up. Ok for the street and Ok for the track. A lot of the Goodguys AutoX crowd have moved to around 400 lb/inch. If you want to do well in AutoX then make the car real stiff.
Stielow Engineering
Old 11-06-2019, 10:25 PM
I went in between. I pulled the 250s off and went with 325. What are you running in the front with the supercharger weight? I currently have 550lbs
Old 11-07-2019, 06:24 AM
Stielow's Avatar
I run 550s lb/in in the front. If you put 325 lb/in on the back then my swag not knowing your rear sway bar would be 700 lb/in. On the new Rival S 1.5 with the correct shock valving that is close to what the DSE track cars have on them.
They ride like crap on the street BTW. I trey that setup in Gunner and hated it.
My (soft) set up on Gunner won the Motorstate Challenge road course segment for Vintage last year. I lost the AutoX because you need the 315 tire on the front for AutoX to do real well. And you need to practice AutoX which I don’t do.
Good luck
Mark
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
dhutton (12-12-2019), kwhizz (11-10-2019)
  #79
Old 12-09-2019, 11:13 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Do you still have any sets of the C&R 40mm thicker bricks and spacer from JA 2.0 you’d like to sell? I know a guy looking for a set.
Instagram- camaroaj
Old 12-10-2019, 07:07 AM
Stielow's Avatar
Sorry sold the last set 10 months ago.
Stielow Engineering
CamaroAJ (12-10-2019)
