Old 05-12-2020, 09:38 PM
Originally Posted by Dave95z28 View Post
Great runs for babying it off the line like that. Seemed to hold the power well enough once it was moving. What tires were you running in the back?
Dave
Track prep was crazy. 345/35/18 Mickey Thompson DR.
Yea I’ll be more aggressive at the next one. This was spike of 19psi but settle to 13-14psi. Once fueling is sorted boost will go up.
Felt like I was on a rollercoaster ride. Was wildly fast feeling. Only babied it immediately off the line. It was floored by the time I was in top of 1st!
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 05-13-2020, 07:02 AM
slimjim's Avatar
slimjim slimjim is offline
*sees video.
off to buy 2 turbos
NC
streamline 68 camaro
Build Thread here
The Following User Says Thank You to slimjim For This Useful Post:
will69camaro (05-13-2020)
  #803
Old 05-13-2020, 08:38 AM
BigBronco's Avatar
BigBronco BigBronco is offline
Originally Posted by will69camaro View Post
The guy helping with my tune said “put an auto in it and go 8s.”
I think it’s gonna go 9s pretty easily at this point. Fuel system upgrades. And a little suspension work I’m im hoping it goes low 9s at mid-high 150s
It will easily go Mid 9's at 158 or so if not more, especially after the new fuel setup.
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
The Following User Says Thank You to BigBronco For This Useful Post:
  #804
Old 05-13-2020, 08:57 AM
Man that's the hope, i'd say i got the bug a little bit based on how EASY the car went deep into the 10s.
Carry 19-20 psi THROUGH 3rd and 4th and I bet that gets it in the upper 150s...Fuel system will be required for that for sure.
Little harder launch and it's there i'm sure.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 05-18-2020, 04:06 PM
Like usual, enough wasn't enough. While the clutch is out and being diagnosed, i just ordered a fuel pump replacement for one of my V modules, that houses twin 525LPH Hellcat pumps. Ordering the lines and fittings to add this as my "secondary" pump setup. This should give me some breathing room on the power side, as i was losing fuel pressure in the pass above. This will be adding an extra 75% fuel flow and should allow me to get close to maxing out those ID1700x if the turbos are up for it. All that's left for fuel system upgrade is the controller (CarlC ) to ship, and a few small fittings.
Texas A&M BSME 2008
1992 Corvette ZR-1
The Following 2 Users Say Thank You to will69camaro For This Useful Post:
Goosesdad (05-19-2020), Roscoe03 (05-18-2020)
  #806
Old 05-19-2020, 10:29 AM
Rodknock's Avatar
Rodknock Rodknock is offline
Do both pumps run all the time, or does the second one kick in under boost? Sorry if it's a stupid question, but I have a huge learning curve to go through, after being out of the hobby for 20 years, and now trying to learn new school
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
Old 05-19-2020, 12:04 PM
CTS-V runs full time, second pump comes on with effectively a "hobbs switch" but believe CarlC is working that into the controller itself. It will come on with 2psi boost.
Texas A&M BSME 2008
1992 Corvette ZR-1
The Following User Says Thank You to will69camaro For This Useful Post:
Rodknock (05-20-2020)
  #808
Old 05-28-2020, 02:17 PM
Trans has been out and put back in. Issue with clutch was slave related and specifically about being a cheap china knockoff piece (From O'Reillys) that had all the markings of a GM piece so i mistakenly assumed same. My fault. Also with new trans and new slave, I should have RE-measured for clutch spacing/shimming needed and I didn't. My mistake.
Trans is back in, with a GM replacement slave, measured out and in the range of what is acceptable per Manuf Recommendations.
I will check this evening to see if the clutch releases like it should after bleeding fully. After that is confirmed I will be re-installing all the turbo piping / exhaust I had to remove, and the new Bowler shifter (previous had split the boot and was leaking).
Old T56 magnum shifter with 300 miles:
New shifter and new seal design:
Based on some signs of fuel starvation and the car having so much left on the table power wise, I've started to collect parts for fuel system change:
Vaporworx controller:
Twin Walbro 525LPH (285s) in custom Housing:
Fancy fuse panel for pump and future amp ANL fuses:
Not shown is the new Fuelab FPR, hoses/fittings, etc needed for the pump and fuel rail feed changes.
Also have some more items on order for changing the WG control to Dome control and twin solenoids. Hoping it all fits around what I already have but there is more work needed there, like drilling and tapping the compressor housing, so that will be a bit.
Texas A&M BSME 2008
1992 Corvette ZR-1
Rodknock (05-29-2020), WILWAXU (05-28-2020)
  #809
Old 05-29-2020, 11:19 AM
python python is offline
Almost 10 years on this thread what a build.
The Following User Says Thank You to python For This Useful Post:
will69camaro (05-29-2020)
  #810
Old 05-29-2020, 12:15 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
It's amazing how time fly's and life sometime's takes precedence and importance over our builds.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
