Old 01-14-2019, 08:42 AM
rideordie28 rideordie28 is offline
Default Starting a new 69 camaro build in my garage.
here is my 69 camaro. i am starting a whole build thread on the car. walking thru the in and outs of what i am using and why. I am a GM performance Engineer and will be posting updates constantly. Check out the agent orange build thread for more info. there will also be alot of parts coming off the car for sale. PM if you are interested in something. most likely it is for sale.
The Following 4 Users Say Thank You to rideordie28 For This Useful Post:
69c4x1 (08-12-2022), fleetus macmullitz (04-29-2020), Roscoe03 (08-02-2021), Spiffav8 (02-20-2021)
  #772
Old 01-05-2020, 10:57 AM
Openers's Avatar
Openers Openers is offline
Ten years into this build now. I know - I’m not fast.
Camaro T/A on Facebook
The Following User Says Thank You to Openers For This Useful Post:
  #773
Old 02-19-2021, 08:55 AM
vet57air's Avatar
vet57air vet57air is offline
Built all in a single garage by me.
https://lateral-g.net/forums/showthread.php?t=58956
The Following 6 Users Say Thank You to vet57air For This Useful Post:
69c4x1 (08-12-2022), BMR Sales (02-22-2021), Roscoe03 (08-02-2021), Spiffav8 (02-20-2021), syborg tt (10-12-2021), Vegas69 (02-19-2021)
  #774
Old 02-22-2021, 12:13 AM
67-ls1 67-ls1 is offline
I put this together myself as a daily driver to get better than 30 mpg. Same paint I bought it with but everything else is upgraded.
1966 Chevelle with 217 ci, 4 cam V6, 6 speed auto, full Hotchkis suspension, Wilwood discs all around. Built for smooth, quiet handling and max MPG.
The Following 7 Users Say Thank You to 67-ls1 For This Useful Post:
camcojb (02-22-2021), dhutton (02-22-2021), Kmelander (08-01-2021), Roscoe03 (08-02-2021), Spiffav8 (02-24-2021), Steve68 (08-11-2021), syborg tt (10-12-2021)
  #775
Old 08-01-2021, 06:45 PM
Kmelander Kmelander is offline
Would love to learn more about that powertrain! Wicked interesting and very nice car! That is an awesome example of how to go green!
Old 08-01-2021, 09:03 PM
Thanks. I got the engine, transmission, wiring harness and ECM from a 2013 Camaro with only 525 miles on it. It’s rated 325 HP and is all aluminum so pretty light. The Camaro was rated for almost 30 mpg on the freeway so I thought if I stayed light I could maybe get 35. I came in a 3,260 lbs with a full tank but so far I’m averaging 28-32 mpg. I did get do one all out max mpg run, driving like there was an egg on the throttle pedal, coasting, etc and got just under 40 but it wasn’t fun
I’ve got full Hotchkis suspension front and rear, Wilwood discs on all 4 corners and a 12.1 steering box so it drives fantastic.
The Following 3 Users Say Thank You to 67-ls1 For This Useful Post:
camcojb (08-02-2021), Roscoe03 (08-02-2021), syborg tt (10-12-2021)
  #777
Old 08-08-2021, 07:26 AM
Yelcamino's Avatar
Yelcamino Yelcamino is offline
Originally Posted by vet57air View Post
Beautiful!
Herb
1966 El Camino LS408/T56Magnum
1966 Chevelle 509/T56Magnum
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 10-12-2021, 07:42 AM
syborg tt's Avatar
Wow, is this car awesome !!!
I was just going to ask about the motor but someone else beat me to it. Very cool indeed and I love that it is a v6 and that you drive and it sounds like you drive it a lot.
Thanks. I got the engine, transmission, wiring harness and ECM from a 2013 Camaro with only 525 miles on it. It’s rated 325 HP and is all aluminum so pretty light. The Camaro was rated for almost 30 mpg on the freeway so I thought if I stayed light I could maybe get 35. I came in a 3,260 lbs with a full tank but so far I’m averaging 28-32 mpg. I did get do one all out max mpg run, drinking like there was an egg on the throttle pedal, coasting, etc and got just under 40 but it wasn’t fun
marty-mj
Old 10-12-2021, 01:50 PM
I do drive it a lot. Everyday usually. It’s currently apart as I’m chasing an annoying rattle in the dash but that shouldn’t take long.
I’m also going to swap to a 9” Ford rearend with posi. I took it to the Wednesday Night Drags near me and it was traction plagued to the point of embarrassment.
Plus, dam Tesla’s are quick. There were a number of them there running low 10s.
The Following User Says Thank You to 67-ls1 For This Useful Post:
syborg tt (10-13-2021)
  #780
Old 10-13-2021, 10:46 AM
syborg tt's Avatar
That is awesome and I hope to the same if I ever finish mine.
Holy Cow, Low 10's in a Tesla. I didn't know they were that fast.
marty-mj
67-ls1 (10-13-2021), 69c4x1 (08-12-2022)
