Old 03-06-2021, 07:29 PM
bkswede bkswede is offline
Looks great! Have you figured out what you’re doing with your cold air intake/filter? Not a lot of space in the engine bay for it...
63 Chevy II - Build in Progress
2017 Camaro ZL1
2010 Mercedes C63 AMG
Old 03-07-2021, 03:17 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Nice fab on the core support for the p/s reservoir.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-18-2021, 12:37 PM
1965NOVA 1965NOVA is offline
Awesome build and thanks for all the ideas. Was wondering what steering column you have installed in your car?
Old 03-19-2021, 08:29 PM
64G-lark's Avatar
64G-lark 64G-lark is offline
Thanks Brian, I am working on a plan to route CAI to the left side. The hole I cut in the core support is going to provide a air intake. I am building a screen to cover the opening. I started with some aluminum angle 3/4 x 3/4 that iI ripped one side down to create a recess for the screen. I cut and welded the pieces together added the screen then capped it with 3/4” wide flat stock. Here are a few pictures that might make more sense.
Thanks 214Chevy.
1965NOVA, The column is a Ididit brand.
The Following 2 Users Say Thank You to 64G-lark For This Useful Post:
camcojb (03-20-2021), waynieZ (05-17-2021)
  #85
Old 03-20-2021, 02:25 PM
Looks great! That should work nicely!
2017 Camaro ZL1
Old 05-01-2021, 09:20 PM
64G-lark's Avatar
Been pulled away for a bit and haven’t had much time, I have the core support in primer and mocked up the overflow tank, PS tank, air intake screen and the lower radiator mounts. Still have the upper mount to complete.
The Following User Says Thank You to 64G-lark For This Useful Post:
camcojb (05-01-2021)
  #87
Old 05-02-2021, 05:04 AM
I really like the air intake screen. That looks great. Good job!
Old 05-02-2021, 07:51 AM
tommycomfort's Avatar
tommycomfort tommycomfort is offline
Impressive work as always Mark!
Tom Farrington
66 Chevelle hardtop (ours) http://www.pro-touring.com/showthrea...PT-build-(ours)
64 Chevelle 4-dr wagon (wife's) http://www.pro-touring.com/showthrea...HAUL-LONG-ROOF
The new shop build https://lateral-g.net/forums/showthread.php4?t=42857
Old 05-02-2021, 08:32 PM
64G-lark's Avatar
Thanks Trey. It came out better than I thought it would.
Thanks Tom.
Old 08-20-2021, 08:01 PM
64G-lark's Avatar
Built a aluminum hold down for the radiator. Trying out some dimple dies.
Bracket for the accelerator pedal.
Then on to the fender supports.
The Following 3 Users Say Thank You to 64G-lark For This Useful Post:
camcojb (08-21-2021), jarhead (09-12-2021), Roscoe03 (08-21-2021)
