Old 06-22-2021, 09:27 PM
egoman's Avatar
egoman egoman is offline
https://lateral-g.net/forums/attachm...1&d=1624418845
The "Biggest" thing in motocross!
My build thread, Transcona, The dirty old Cougar!
https://lateral-g.net/forums/showthread.php?t=58877
The Following User Says Thank You to egoman For This Useful Post:
Goosesdad (07-12-2021)
  #202
Old 06-22-2021, 09:29 PM
egoman's Avatar
https://lateral-g.net/forums/attachm...1&d=1624418950
  #203
Old 06-28-2021, 06:16 PM
egoman's Avatar
This post has a lot in it. I bought a truck for the powertrain and to use as a dummy. I also finally pulled the trigger on a Harbor Freight welder just to see if you could build a car with one.
I got a roller motor 351 with an OD transmission and assorted parts to use for mockup. I have the thank my buddy Sheldon Finkel for this find and the sprint car races for getting me close to the Harbor Freight.
Lots of pictures of the first welding project, which for everyone is the cart for the machine. It’s been a good machine so far. As much as I think they are hacks, the guys from B is for Build are who sold me on this machine.
https://lateral-g.net/forums/attachm...1&d=1624925808
Old 06-28-2021, 06:20 PM
egoman's Avatar
https://lateral-g.net/forums/attachm...1&d=1624926043
Old 07-04-2021, 10:29 AM
egoman's Avatar
Just doing the front bars shouldn’t be that hard but I am kind of picky about straight so it always takes longer than it should. I am also trimming the fender wells, and because of what I am doing going forward that has to be done quite accurately.
https://lateral-g.net/forums/attachm...1&d=1625416134
Old 07-05-2021, 06:49 PM
egoman's Avatar
In a previous post I talked about how precisely that the inner fenders had to be cut. The reason for that should be obvious right now. They are remaining and will be tied to the inner panel being built. This would have been a great time for a laser to guide me along.
Oh and I did some, body surgery while I was in there today. If it looks painful you can rest assured it bloody well was! OUCH. Remember kids keep both hands on the grinder.
Used that as a lesson for the kids the Monday after I did it. They thought it looked painful too!
https://lateral-g.net/forums/attachm...1&d=1625532561
Old 07-05-2021, 06:54 PM
egoman's Avatar
https://lateral-g.net/forums/attachm...1&d=1625532704
Old 07-07-2021, 04:24 PM
egoman's Avatar
If you have been following along you may have caught on that this build is behind the calendar.
We are about 1-1/2 years back as of right now. My idea is that there is always material even as the winter months basically shut me down. I would work in the cold no problem but my garage has more holes in it than Harrys barn.
Just to give you an idea of what to expect I have only posted material for you in the spring summer and fall months when I have actually added to the "bank" of stories. What that means is every post you see now has another coming down the road.
Another thing is these posts are 1 days work. That is why sometimes you will see a project that looks like it should go with the prior one but I didn't finish it in one day.
The extended winters here in Canada allow me to play catchup for those following.
I hope to be able to turn the key with you guys watching in real time!
https://lateral-g.net/forums/attachm...1&d=1625697121
Old 07-10-2021, 09:18 AM
egoman's Avatar
Some days you just need to help a friend out. It also helps to work on something other than the car.
My riding buddy and good friend Chris Ryan needed some help and that’s what I do.
Just a mounting system for a wet kit tank for his truck. No splainin for these pics!
https://lateral-g.net/forums/attachm...1&d=1625930278
Old 07-10-2021, 04:05 PM
egoman's Avatar
I don’t like doing body work ever! The idea of stitching panels together is why I always raced cars with a sheet metal body where I could just flop on a new panel. But the inner panels have to attach to the fender-wells so here we go.
https://lateral-g.net/forums/attachm...1&d=1625954701
