Old 06-24-2021, 08:43 PM
rocketrod rocketrod is offline
Payment sent for Anvil lower valence and headlight buckets.
Rod
1969 Camaro - LS2/4L70E
Old 07-07-2021, 02:39 AM
sixnina's Avatar
sixnina sixnina is offline
Will brakes work for a 69 Camaro?
Old 07-23-2021, 11:54 AM
69CamaroPT 69CamaroPT is offline
Fronts would work but rears are for BOP setup.
69 Camaro
67 GTO vert
Old 07-23-2021, 12:00 PM
speck4478 speck4478 is offline
Just wanted to let you know that your mailbox is full,
I wanted to follow up with the question I sent to you earlier. I meant what motor is the radiator set up for.
Old 07-26-2021, 10:57 AM
Bygblok's Avatar
Bygblok Bygblok is offline
how much offset change was there going with those front and rear brakes? My 66 Buick Special is really squeezed pretty hard right now for front and rear tire clearance so I can't do any more offset. Also on the rears did you still have the BOP rearend under it or a chevelle-type 12-bolt? Thanks, Bill
The lowest common denominator can ruin your whole day!
Bill from Pensacola
1970 Camaro(abused daily)
1966 Buick Special(work in progress)
2019 Camaro ZL1/1LE too much fun to be stock
2021 GMC AT4 Duramax......the puller
