Old 08-11-2021, 08:13 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
Default If your using a Ron Sutton subframe and control arms, you should probably read this.
Just an FYI for anyone running a Ron Sutton Race Technology sub frame or control arms. People are already aware of the failures on his two piece, curved design. If you have the one piece lower design, it can (will) fail as well.
Here you can see the crack in the arm. This is on a low 3K pound car, 315's, and maybe has done 30-35 AutoX events, a few track days, and under 10 thousand street miles. If that's not scary enough, the front lower control arm mount is also a failure point. This high load attachment is mounted in a cantilever arrangement with only one and a half sides welded/supported at the bottom, below the load path.
Here are a few pics of one that tore off, and a few pics of the other side, stress cracked, and about to tear off. I'm not posting this to call out Ron Sutton as a hack parts designer and fabricator, although it does make for a happy coincidence, but to let you guys running this stuff know you need to make some changes in the design if you want it to be safe.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
The Following 11 Users Say Thank You to CJD Automotive For This Useful Post:
572Camaro (08-12-2021), 69C40Hx (08-19-2021), 72Z/28 (08-16-2021), BigBronco (08-11-2021), BMR Sales (08-11-2021), Build-It-Break-it (08-11-2021), camcojb (08-11-2021), dontlifttoshift (08-11-2021), jarhead (09-12-2021), Jtomas801 (08-17-2021), redfire69 (08-16-2021)
Old 08-11-2021, 09:57 AM
BigBronco's Avatar
BigBronco BigBronco is offline
Thanks for sharing. I really hope people stop utilizing him/his company at all.
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
Old 08-11-2021, 12:20 PM
BMR Sales's Avatar
saw that on FB this morning. POS!
Old 08-12-2021, 07:34 AM
dontlifttoshift's Avatar
I was driving the car at the CAM Challenge when the LCA mount tore off the frame. Thankfully it was uneventful as the car just washed way wide of my line and there was plenty of runoff. Zero damage to the car.
That bracket is completely unsupported where the load is. Under breaking the LCA is pulling on it and in cornering it is pushing on it and it was constantly bending.
Donny
The Following 4 Users Say Thank You to dontlifttoshift For This Useful Post:
camcojb (08-12-2021), Che70velle (08-12-2021), kwhizz (08-21-2021), mfain (08-12-2021)
