Old 10-27-2022, 06:56 PM
syborg tt's Avatar
Default Passenger Side Banjo Bolt Leak (( 10-27 -22 ))
It looks like I figured it out and apparently the line is hitting the caliper before the banjo bolt can be tighten down all the way.
Here is a picture of the Drivers Side and it doesn't leak.
Here is the Passenger side and you can see it is resting on the caliper body.
Once again this line is coming off and being bagged.
Back to my Grandfathers vise.
2nd Attempt as the 1st one was not successful.
Looks like it's going to work.
Line is back on and I will try to bleed the brakes again tomorrow.
marty-mj
The Following 5 Users Say Thank You to syborg tt For This Useful Post:
camcojb (10-29-2022), fleet (10-29-2022), Goosesdad (10-29-2022), Roscoe03 (10-27-2022), waynieZ (10-29-2022)
  #1952
Old 10-27-2022, 07:00 PM
Nice work. I've had this happen before too. Fixed it in the same manner as well.
The Following 2 Users Say Thank You to WSSix For This Useful Post:
Roscoe03 (10-27-2022), syborg tt (10-28-2022)
  #1953
Old 10-28-2022, 03:56 AM
Cramer4918's Avatar
I’m glad you got it figured out, Marty. Hopefully that will be the fix.
Those little Gremlins are the always the ones to set you back.
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following User Says Thank You to Cramer4918 For This Useful Post:
  #1954
Old 10-28-2022, 08:00 AM
syborg tt's Avatar
I was considering calling Tobin and getting some new lines with a bend in them but I it looks like I am just use these.
Let's not also forget that we spend time looking at other builds and seeing something cooler that you just have to do.
and I have my fingers crossed.
marty-mj
andrewb70 (10-28-2022), fleet (10-29-2022)
  #1955
Old 10-28-2022, 12:12 PM
Marty,
What do you are for calipers? That size rotors? I didn’t see anything about them.
Thanks,
Jimbo
The Following User Says Thank You to Jimbo1367 For This Useful Post:
syborg tt (10-29-2022)
  #1956
Old 10-29-2022, 05:29 AM
syborg tt's Avatar
Originally Posted by Jimbo1367 View Post
Marty,
Thanks,
Jimbo
The brakes are from Tobin at Kore3. It’s a c5 / c6 kit with the DSE Corvette Reduced angle brake booster. It like having modern factory brakes on an old car. One of the other benefits is if I break down on the side of the road, I can go to Napa or AutoZone or any other local auto parts stores. I’ll be back on the road.
Sorry, I just added pictures
marty-mj
fleet (10-29-2022), waynieZ (10-29-2022)
  #1957
Old 10-29-2022, 02:10 PM
It looks good to go as far as room.
The Following User Says Thank You to waynieZ For This Useful Post:
  #1958
Old 10-29-2022, 08:06 PM
syborg tt's Avatar
It always scares me when I bend a line. My brain tells me I shouldn't do it as it could fail. However, I just barely moved it.
marty-mj
Old 10-30-2022, 12:06 PM
Marty,
Thank you for the response with pics. Have you driven the car with the OEM brakes vs. the C5/6 brakes? If so, what are your thoughts of this modification?
I’ve been eyeballing Kore3 brakes for a while Thanks again
syborg tt (10-30-2022)
  #1960
Old 10-30-2022, 01:39 PM
syborg tt's Avatar
Marty,
Hi Jimbo,
I did not drive my car with the original brakes as my car was only a roller when I purchased it. However, I have driven my buddy's late 2nd Gen with factory Disk/Drum set up and I was amazed at the difference. My car actually stops just like a new car. His car felt like I was driving an old car with crappy brakes.
You can't go wrong with the Kore3 stuff just make sure you buy the DSE Brake Booster set up and you will have tons of fun accelerating into a corners with ample braking prior to the corner.
marty-mj
