Old 12-16-2006, 04:32 PM
jigga99 jigga99 is offline
Default swaybar angles??
i put in a 1 1/4 swaybar in, and the back of the sway bar towards the back of the car, is were it bolts to the lower a-arm, its angle is quite steep from lowering the car, will this harm the performance of the bar? do i need to cut the sleeve spacer? so i guess my question is should the bar sit level?
Old 12-17-2006, 01:44 AM
71Nova 71Nova is offline
What kind of car is it mounted into? You can usually just use a shorter bolt and sleeve to make the sway bar more level. I had to do that with my car.
David
Old 12-17-2006, 11:12 AM
69 camaro, thats what i was thinking
Old 12-17-2006, 01:30 PM
chicane's Avatar
chicane chicane is offline
Use of the 63-82 Corvette end links will solve this issue.
Energy Suspension part number: 9.8120
