Old 09-25-2023, 07:03 PM
syborg tt's Avatar
Default GM LSX Tall Valve Covers (( 09-23-23 ))
Good news the second set of Valve Covers arrived.
These are so much nicer then the last set.
Coils coming off again.
Now this is how a valve cover should look.
Need to fix a loose blind nut.
I moved over the coil mounts from the Carbon Valve Covers.
Torque to proper spec.
Drivers Side
Since I didn't show this on the Passenger Side I did put a little bit of oil on the hardware.
Sucks to have to cover up the LSX logo
Ugh, I missed a loose blind nut.
Need to redo this line.
Good News they don't leak.
marty-mj
The Following 6 Users Say Thank You to syborg tt For This Useful Post:
214Chevy (09-26-2023), fleetus macmullitz (09-25-2023), Jimbo1367 (09-27-2023), Ricochet (10-09-2023), rixtrix1 (09-27-2023), Roscoe03 (09-27-2023)
  #2272
Old 09-26-2023, 05:36 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Very nice work Marty!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
syborg tt (09-28-2023)
  #2273
Old 09-27-2023, 05:22 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Awesome work Marty !
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
The Following User Says Thank You to Sheck44 For This Useful Post:
  #2274
Old 10-01-2023, 12:07 PM
syborg tt's Avatar
Default Optima Battery has been discharged and recharged (( 09-24-23 ))
So the optima battery is back and it is fully charged. I dropped it off at my buddy's shop so he could use the big Optima
charger so it could be reconditioned and charged back up.
I am getting tired of taking this battery in and out.
However, I am getting really good at it.
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
camcojb (10-01-2023), fleetus macmullitz (10-01-2023), Ricochet (10-09-2023)
  #2275
Old 10-02-2023, 06:05 PM
syborg tt's Avatar
Default Dr EFI Andrew is in the house ''Virtually'' (( 09-29-23 ))
Well, Andrew is back in the house and it's a Friday.
Andrew was kind enough to log back into my car and tweak the tune just a little bit. He confirmed my PWM fan connection
to the Holley worked and we figured out that my thermostat wasn't opening.
We also assumed that there was still air in the cool heads and he sent me out to get the Funnel fill set up.
marty-mj
Cramer4918 (10-03-2023), Goosesdad (10-06-2023)
  #2276
Old 10-02-2023, 06:31 PM
syborg tt's Avatar
Default Swapping the Thermostat (( 09-30-23 ))
Back in the garage and plan to change out the thermostat.
please don't tell my wife.
Here we go again.
So, as I was taking the Thermostat housing out one of the bolts fell directly behind the battery against the core support.
Thank god the bolt was steel and I was able to fish it out from behind the battery with a magnet.
Housing is back on and I hope this works.
While I was there I finally put the cover on the positive terminal.
Back together again.
Off to the grocery store to get more distilled water.
I also picked up some Windmill Cookie's
Picked up the Funnel Fill kit.
50 Dollars at Advanced Autoparts and the China Knock off is $20.00 on Amazon.
I can't believe how well this works.
Clock works
Calling it a night and heading to the trail to get a ride in.
marty-mj
andrewb70 (10-02-2023), camcojb (10-03-2023), Cramer4918 (10-03-2023), fleetus macmullitz (10-02-2023), Goosesdad (10-06-2023), Ricochet (10-12-2023)
  #2277
Old 10-02-2023, 06:43 PM
andrewb70's Avatar
I forget where I saw the funnel being used for the first time, but after I tried it, I was sold.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 3 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (10-03-2023), Cramer4918 (10-03-2023), syborg tt (10-03-2023)
  #2278
Old 10-03-2023, 06:49 AM
Cramer4918's Avatar
I’m glad you’re making progress, Marty. It’s playing out like you said about the last 10%. Hopefully not much longer.
What PWM fan controller are you using?
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following User Says Thank You to Cramer4918 For This Useful Post:
  #2279
Old 10-03-2023, 07:05 AM
andrewb70's Avatar
He has the C6/Ford Fusion control box.
Andrew
Instagram @dr__efi
My YouTube Channel
  #2280
Old 10-03-2023, 09:28 AM
syborg tt's Avatar
This quote is so true
The last 10% is 90% of the work.
and tonight I am removing the starter trying to figure out where the leak is coming from.
Possible the crank position sensor.
marty-mj
