Old 11-17-2023, 04:10 PM
fleetus macmullitz's Avatar
“I am pretty sure it was Mark that said this. If you have an hour to spare head out and do one of the small projects. I installed
a Burn Out Switch to prevent my friends from doing a burn out when I am not around.”
MJ,
I’m guessing it will also stop the wife & kids, the family dog, nosy neighbors too?
The Following 2 Users Say Thank You to fleetus macmullitz For This Useful Post:
Ricochet (11-17-2023), syborg tt (11-20-2023)
  #2312
Old 11-20-2023, 01:35 PM
syborg tt's Avatar
Default Drivers Side Door Panel (( 11-12-23 ))
I started working on the drivers side door panels
The table is back out and so are my daughter towels from when they were little.
Looks like I need four more clips
I placed the template on the door and started trimming the panel to make them work.
Way off
This is a very tedious task so be patient.
More interior parts
marty-mj
The Following 4 Users Say Thank You to syborg tt For This Useful Post:
Cramer4918 (11-20-2023), EVIL SS (11-30-2023), fleetus macmullitz (11-21-2023), Roscoe03 (12-15-2023)
  #2313
Old 12-12-2023, 04:49 PM
syborg tt's Avatar
Default Seat Belt Planet Harness / Ride Tech Roll Cage (( 11-20-23 )
Honest I have been working on the car however, not nearly enough.
Yet another To Do List
Next up is to flip the seat belt bracket so it can actually work.
Nope this won't work
Next time this car is off the lift I am going to move it over a little bit.
Six Day's later !!
marty-mj
fleetus macmullitz (12-13-2023), Roscoe03 (12-15-2023)
  #2314
Old 12-12-2023, 05:03 PM
syborg tt's Avatar
Default Classic Industries Door Panel (( 11-26-23 ) Part 1
Time to install the Classic Industries Door Panel.
I ran the factory screws in from the backside so they would make a mark on the door panel so I can punch a hole. I used
the tape to give me a reference so I new where to push on the panel.
Enlarging the holes for the blind nut.
Don't tell my wife I borrowed this.
Little paint and primer in one.
Test fitting the Template
Nailed it !!
Next up the door handle.
Final trim
I installed these washers in between the door panel and red door pull.
marty-mj
  #2315
Old 12-12-2023, 05:15 PM
syborg tt's Avatar
Default Classic Industries Door Panel (( 11-26-23 ) Part 2
Next up ... Install the razor sharp retaining clips.
Time to remove the door panel so I can install the remainder of the clips.
Best tool ever for removing the door panel.
So, I have remote mirror but I am afraid to cut the hole in the door panel.
More notes (( yes I have memory issues ))
I plan to come back and glue the leather to the back side of the door panel.
Cut the hole for the window cranks and yes I am staying old school.
A little paint and primer in one is needed.
I placed the water shield on the template and made the necessary cuts.
yep, I have misplaced one of these washers.
More notes
marty-mj
  #2316
Old 12-12-2023, 05:19 PM
syborg tt's Avatar
Default Yet another list (( 11-28-23 ))
Well, it was a good run and it looks like the Harbor Freight tool was only able to do a few dozen nutzerts.
I have one bolt left, maybe I will make a keychain with it.
marty-mj
camcojb (12-13-2023), Roscoe03 (12-15-2023)
  #2317
Old 12-12-2023, 05:21 PM
syborg tt's Avatar
Default Ugh, Trans is leaking (( 12-01-23 ))
Yep, just one more thing to worry about.
marty-mj
  #2318
Old 12-12-2023, 05:38 PM
syborg tt's Avatar
Default Time to finish the drivers door and the To Do List (( 12-01-23 )
Thank goodness I bought that panel popper.
Fixed !!
I am not the person that made that brutally awesome hole in the door and I have no intention of removing it as it part of the cars history.
Loose bracket fixed !!
A little Eastwood Patina sauce in the door.
Installing the water shield hopefully for the last time.
I traced the water shield so I know where to install the caulk strips.
Next time I will look for my little roller.
Calling it a night.
marty-mj
camcojb (12-13-2023), EVIL SS (12-13-2023), fleetus macmullitz (12-13-2023), Roscoe03 (12-15-2023)
  #2319
Old 12-13-2023, 01:36 PM
Enjoyed seeing your work…great update MJ.
The Following User Says Thank You to fleetus macmullitz For This Useful Post:
syborg tt (12-13-2023)
  #2320
Old 12-14-2023, 10:42 AM
syborg tt's Avatar
Default Door Panel is finally on (( 12-02-23 ))
Here we go and I hope this is the last time I have to take it on and off.
These Classic Industries Door Panels are so nice.
Since the trim isn't on the Jam I tapped it off to protect the door panel.
Since the car is on the right right side of the lift ramps I decided to hang a kneeling pad on the wall to protect the door.
marty-mj
camcojb (12-14-2023), Roscoe03 (12-15-2023)
