01-22-2025, 09:59 AM
Impressive work. Thanks for the updates
The Following 3 Users Say Thank You to RKROEGER For This Useful Post:
03-02-2025, 06:48 PM
Here is the process for the flanges between the dash, the A-Pillar and the kickpanel. Wood brackets hot-glued to each piece and the connected together with some scrap sheet metal. Did this for most of the interior panels.
Did this in the car so the brackets are in the exact position.
Then pulled it out of the car and put it back together on saw-horses.
Then laminated the flanges, these will connect the parts together with bolts and rivnuts. Interior guy may modify this but that's above my paygrade.
The Following 7 Users Say Thank You to Goosesdad For This Useful Post:
03-02-2025, 06:56 PM
Printed some plastic molds to help make hand reliefs in the A-Pillar covers. I tried to keep the hand grabs tight to the A-Pillar so they didn't stick out funny and always knew I would have to modify the cover to provide space for knuckles.
The Following 3 Users Say Thank You to Goosesdad For This Useful Post:
03-02-2025, 07:15 PM
Printed a bezel for the GPS/Track Computer.
Some more test-fitting
Fab'd the thresholds.
The Following 9 Users Say Thank You to Goosesdad For This Useful Post:
03-03-2025, 04:53 AM
Very nice work!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
03-03-2025, 08:45 AM
Originally Posted by 214Chevy
Very nice work!!
03-04-2025, 07:25 AM
Very impressive.
A bunch of effort for sure & it looks like you nailed your vision.
03-11-2025, 07:58 PM
That dash looks like a fighter jet cockpit! 🤘
The Following User Says Thank You to Roscoe03 For This Useful Post:
04-02-2025, 01:26 PM
Thank you guys!!!
Will mount the fuse panel above the trans tunnel for easy access but need to mount it vertically to not interfere with the AC ducts. Printed this plastic bracket. ABS plastic and it's only 20% solid so it's light but I couldn't break it by hand. Made the areas with bolts 100% solid for added strength (not shown is I used threaded inserts that I melted into the holes and also used nylocks to ensure the fuse panel never came loose. Yep, sorta enamored with this 3D printer, certainly opens up options. I will make an access panel in the side plate for the center console, coming soon.
The Following 6 Users Say Thank You to Goosesdad For This Useful Post:
04-04-2025, 10:52 AM
I don't know how I did things before I got my 3D printer. I takes build quality to a whole new level.
Instagram- camaroaj
The Following 2 Users Say Thank You to CamaroAJ For This Useful Post:
Thread Tools |
Display Modes |
Linear Mode
