Old 02-13-2007, 05:46 AM
kennyd's Avatar
kennyd kennyd is offline
i personally did not like jim meyer's set-up , because the crossmember sits to low , in turn makes it hard to get the car low without having the crossmember on the ground first . also the rear is even worse than the front . if you are not woried about having the car on the ground , i believe this will drive and ride great .
i prefer airride tech. rear 4 bar set up , you can sit the car on the ground and keep more ground clearance .
i also have used a scott's front clip in a 55 ,better but it still had some problems you can get easily fixed .
fatmans , also makes a front clip . i have a real good friend who has one under a 55 it looks ok so far .
another 55 sedan we used drop spindles , power rack, tubular controll arms , and sway bars . it drove the best of all but was ugly because it still had the stock clip .
i aslo have a 57 with stock arms , sway bars , cool ride bags , and a 600
power box it drives real good also
hope this helps .
Old 02-13-2007, 07:52 PM
evans56 evans56 is offline
Originally Posted by jy211
how easy/hard was the installation?
The installation was not hard at all. Everything was made to fit a 56 chevy frame with no cutting. Just follow the instructions measure and weld. The crossmember does hang a little below the frame so if you want the car on the ground I would probably use a different setup, but for what Im doing this setup will work fine.
Steve Evans
Old 02-14-2007, 07:36 AM
Roger Poirier's Avatar
Roger Poirier Roger Poirier is offline
Welcome, I'm like Bill Howell, how can you not love all these cars. Super cool project.
R.P.
official car name - DELIVERANCE
Old 02-14-2007, 11:20 AM
ProTouring442's Avatar
On my dad's car we welded in the front sub from a '79 Trans Am. Also, I think RBs (or something like that) makes a front sub that uses G-body or F-body parts. It's also a weld in. We looked at it, but felt that it dropped the front too much.
Shiny Side Up!
Bill
'72 442 "Inamorata"
www.FQuick.com/ProTouring442
Old 02-14-2007, 03:42 PM
CraigMorrison's Avatar
CraigMorrison CraigMorrison is offline
Welcome! Tri5's are cool It's a lot of fun to get those big old boxes around a corner.
Old 02-14-2007, 05:06 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Welcome aboard!! Nice to see more tri-fives coming aboard. I'm kinda partial to them. Good luck on the project and keep us updated.
Brent
Old 02-14-2007, 08:19 PM
R.P.
Thanks, There are some amazing cars on this site. I wasn't sure if I should put mine on here or not.
Steve Evans
Old 02-14-2007, 08:43 PM
Thanks, I was at Sacramento Autorama this weekend and was checking out one of your tri-5 chassis. My next car Im definetly going with that chassi. I like how mine is coming out but its still a 50 year old frame.
Steve Evans
Old 02-14-2007, 08:58 PM
Brent
Thanks Brent, I found a link to this site while I was looking at your site. I did a search for tri-5 chevys and found your site. The 57 you built is to cool and I can't wait to see the 55. Im still trying to decide what tire and wheel size to put on the car. 17-18 or 18-20. I like the 18-20 but worry about bending wheels if I hit something. Any suggestions would be great.
Steve Evans
Old 02-15-2007, 05:29 AM
TravisB TravisB is offline
We have had everything from 17,18,19,20, and 22in wheels and have never had a problem with a bent wheel.
You might want to check your ride hieght options with a 20 on the rear and the meyer rear clip
Kenny Davis Hot Rods
