Old 04-23-2007, 06:30 PM
67velle's Avatar
67velle 67velle is offline
Default tire overall size
can any one tell me where to get tire overall diameters????
Old 04-23-2007, 06:34 PM
cheezer cheezer is offline
Usually at the tire manufacturers web site or catalogue you will find all the technical information about each size such as section width, tread depth, etc., including overall diameter.
cheezer
Old 04-23-2007, 06:41 PM
JamesJ JamesJ is offline
try ntw, discount tire, site like those, they usay have conversions
James J.
Old 04-23-2007, 06:43 PM
JayR JayR is offline
Lateral-G Supporting Vendor
Check out this site. It's a "must bookmark" for most of us here.
www.rims-n-tires.com/rt_specs.jsp
Old 04-23-2007, 07:15 PM
ironworks's Avatar
example 295 Divided by 25.3, Times aspect ratio, times 2, plus rim size
295/25.3= 11.66X.3= 3.49X2=6.996+19= 25.99
I do it every day, they should teach that in high school, then I would have paid attention.
Old 04-23-2007, 07:29 PM
TravisB TravisB is offline
you can also take that one step further and get sidewall height.....
Kenny Davis Hot Rods
Old 04-24-2007, 08:22 AM
98ssnova's Avatar
98ssnova 98ssnova is offline
cool site thanks
Old 04-24-2007, 06:33 PM
BRIAN BRIAN is offline
The calculator and above formula are great info.
Problem I have noticed is different MFG'S even with the exact size have different specs. Some are off quite a bit. If you log onto TIRERACK.COM and simply plug in your size and then hit specs. You will see exact size tires vary from mfg to mfg. Also note how rims size changes measurements.
I used to build bikes and the tire sizes seemed to have nothing to do with what the mfg's had on their sidewalls. If you want to be very accurate check with the mfg's specs.
Now if I can just stop playing with that calculator on the web site. Great info.
Old 04-24-2007, 06:57 PM
67velle's Avatar
thanks jason that,s just what I needed
Old 04-25-2007, 11:46 PM
surreyboy
Guest
Posts: n/a
tirerack.com has specs on each tire they sell, including overall diameter. works awesome when your deciding on what tires you want on the front and rear without getting something totally off
