Old 05-17-2007, 12:44 PM
rich-allen's Avatar
rich-allen rich-allen is offline
Default Headers for LS2 in 1st gen camaro
Alright, I called Kooks and they told me "they didn't make a set of headers that fit an LS2 in a 67 camaro". Scott has a set for his LS7 and I know I seen them on an LS2 before.
What gives? I know S&P sells them but I was set on Kooks.
Any help would be appreciated.
Rich
Old 05-17-2007, 01:31 PM
fletcherscustoms fletcherscustoms is offline
I just happen to have new set of Stainless 304 stepped headers from ATS for sale in the classifieds
Old 05-17-2007, 01:39 PM
Rich-
Good talking with you on the phone. The Kooks headers that Scott has were for a 4th gen, and a few tubes were modded to make them fit. He is also running a Wayne Due frame that uses stock style parts, but the clearances are not the same as a factory frame.
Tyler
Old 05-17-2007, 02:07 PM
rich-allen's Avatar
Great talking to you also Tyler.
After everything I learned talking to you, I decided buy your headers. After spending $3k today and the $12K I spent the week before I need to wait at least till middle of next week before I pull the trigger.
Talk to then,
Rich
Old 05-18-2007, 04:26 AM
shanekennedy shanekennedy is offline
http://www.stainlessworks.net/cart/i...4eea3e2d47334c
just ordered a set of these for my 68 thru group purchase
Old 05-18-2007, 05:37 AM
rich-allen's Avatar
With my heads, cam, roller rockers and intake, I need 1-7/8" headers and SS works doesn't make them.
Old 05-18-2007, 06:47 AM
PTAddict PTAddict is offline
Rich,
I wouldn't assume you need 1 7/8 headers. In fact, I'll go stronger than that - 1 7/8 headers may very well lose average power compared to 1 3/4 on your combo. You have to remember that LSx motors have about 1.60 dia exhaust valves, and exhaust ports no bigger than about 1 5/8 at their widest dimension. Going too large on header diameter just loses scavenging efficiency without substantially improving flow, because the exhaust port becomes the primary restriction.
My LS1 AFR/FAST 90/Cam car made an easy 453 RWHP with 1 3/4 headers. LG motorsports has made over 600 RWHP on radically modified LS7s - with 1 3/4 headers. I'd go with headers that are well constructed and fit. And there are really just three choices for "off-the-shelf" - Stainless works, Hooker, and ATS (ATS will shoot me for calling theirs off-the-shelf).
Edit: And I should add, before Tyler jumps in here, that their 4-2-1 design does offer theoretical advantages in creating a broader powerband, and definite physical advantages in ground clearance. They are the headers I plan to use on my '69 LS7 project, and if money is not a major object ... go for it.
Old 05-18-2007, 10:24 AM
We worked with Burns and Katech to develop our header lengths, diameter and steps to make the most power we can over the entire power curve. LSX engines like to breathe, and the LS2 is no exception to this. the 1-7/8" primary to a 2" to a 2-1/8" to a 3-1/2" collector was determined to be ideal for the engines. I trust Katech over anyone in the LSX industry to make that call.
Tyler
Old 05-18-2007, 11:19 AM
Sorry to keep beating this thread, but I'm always bugged when people get too obsessed with big headers. Headers are probably the most poorly understood element of a high performance engine. Headers aren't there to assist "breathing" in the sense of maximizing exhaust flow - otherwise, all headers would be designed with the largest, shortest primaries possible, dumping into the largest collector possible, and we'd be done with it. Headers are actually tuning devices designed to assist *intake* flow, and a too-large header will not do its job as well.
Here's an article from David Vizard which does a nice job of simply summarizing the role of headers and exhaust in a high-performance engine:
http://www.popularhotrodding.com/eng...exh/index.html
And if you're more into it, and can handle a slightly more technical discussion, download the Dynomation user's manual and read the chapter on Wave Dynamics analysis from this location (warning - 40+ MB):
http://proracingsim.com/downloads/Pr...sersManual.pdf
And if you're really into it, like me, buy the actual Dynomation product and fascinate yourself experimenting with different intake, cam, and header designs and watching the effects on such things as P-V traces and HP/Torque curves.
Old 05-18-2007, 01:36 PM
chicane's Avatar
chicane chicane is offline
...If your really, really into it...
Learn about and utilize the Burns "X-Program". It was one of the more profound reasons ATS worked with Burns to develop their LSx header.
Its not an obsession. Its an insight overlooked by far too many.
