Old 07-19-2007, 07:19 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Default Help with running exhaust around Chris alston G-bar
I installed the G-bar and know I can't figure out how to run the exhaust.
I had the standard over the axle setup before but with the G-bar I don't see how that's possible..
has anyone else installed the G-bar on a 1st gen?
Pictures of exhaust routing would be cool.
Thanks for the help,
Rich
67 RS/SS
Old 07-19-2007, 08:52 AM
rich-allen's Avatar
Talked to chassisworks and they recommended going under.
Thanks anyway.
Rich
67 RS/SS
Old 07-19-2007, 09:40 AM
dhutton dhutton is offline
Air Ride says that Stainless Works has an exhaust that will work with the Air-Bar. You might give them a call.
I also have a G-Bar and one thing I'm considering is using a narrowed minitub style fuel tank to make the exhaust routing easier. Another option is side exit exhaust but I think this might interfere with subframe connectors.
I think Dr. Gas sells oval exhaust pipe etc that can be used to go under if you decide to go that way.
Let us know what you come up with since there is a lot of guys installing the G-Bar.
Old 07-20-2007, 02:34 PM
darren@ridetech's Avatar
darren@ridetech darren@ridetech is offline
Here is a couple shots of the prototype Stainless Works piece.
Old 07-21-2007, 06:36 AM
id use header wrap on the pipe close to the airbag or have the pipes ceramic coated.
Old 07-23-2007, 10:38 AM
Marcus SC&C's Avatar
Look at how the exhaust is routed on a Chevelle. The overall suspension configuration is similar and there looks to be plenty of room to run it that way. Just run the pipes inboard of the upper links rather than outboard. There are enough differences that A body tailpipes probably won`t fit but a set of Flowmaster universal tailpipes (which are multi piece) or 2 piece A body tails might fit with a little tweaking. Mark SC&C
Old 07-30-2007, 05:04 AM
rich-allen's Avatar
Thanks for the help
67 RS/SS
