Old 08-26-2007, 02:56 PM
TonyG TonyG is offline
Sorry guys.. I haven't checked this thread since it wasn't getting any interest when I started it.. lol. Anyways.. I was leaning towards 18's all around since I would like to do drag radials. But my original plan was 18's and 20's.
Travis.. you and I had talked several times before when I first got the car about the mini-tub and a few other things. I am going to PM you about the wheels incase you haven't looked back here.
Thanks guys.. I will check here more frequently and keep you updated.
I am building the car all myself with the hopes of learning and maybe drummin' up some business on the side.
thanks again.
65 Malibu "Liberator"
91 Fox Coupe SSP "Emma"
Old 08-31-2007, 11:28 AM
class67's Avatar
class67 class67 is offline
The 18's and 20's will work, I had them on a 65 El Camino. Watch your back spacing!
Old 09-01-2007, 05:47 AM
I measured the face of the drum to the fender lip and got 4.75 inches. So, on a 20X8.5, a 4.25 backspace would be plenty right?
Old 09-25-2007, 07:46 PM
65 'buSS 65 'buSS is offline
Default Where I ended up
I also have a '65 Malibu SS. I also wanted to get the stance "right". Went with Airide for that. On the front I have the tall B body spindles with Hotchkis upper arms, Baer 13" brakes. I was able to run 17 x 8 w/5.5 bs and 245/45 Nitto 555's. In the back I managed to squeeze 275/40 Nitto 555's on 18 x 9.5w/ 5.5 bs. To make them rear fit required stretching the rear quarters an inch on each side.
Nice to see another early A body in the mix !
Old 09-26-2007, 07:28 PM
I am planning to trim the inner lip of the rear quarters and also doing a mini-tub.
