Old 09-09-2007, 01:04 PM
J2SpeedandCustom J2SpeedandCustom is offline
Is the motor grounded properly? Sounds like it's ignition related. Is the dist off a tooth? or not advancing properly? What timing are you running?
Jeff Allen
J2 Speed and Custom
Old 09-09-2007, 01:28 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
It is grounded, none of that changed.
Dist was never removed so it can't off a tooth
and we have played with the advanement quite a bit to try and get it to run right........
www.hotrodderjournal.com
Old 09-09-2007, 01:34 PM
aany001's Avatar
aany001 aany001 is offline
whats a compression test say in all cylinders?? What is the mileage on this engine??? is it possible that the timing chain has jumped?? start from the basics and make sure the your number is located properly yada yada yada....even make sure the dist cap hasnt burned a hole in it some where.good luck
Steve
Old 09-09-2007, 09:37 PM
I too thought about a piece of intake gasket getting into the intake runner....another thing I have seen alot after an intake swap with no oil change right after is the camshaft going flat. Coolant gets spilled into the lifter valley and gets sucked up by the oil pump at start up.
Old 09-10-2007, 08:01 PM
aany001's Avatar
any luck on getting your engine going??
Old 09-13-2007, 08:19 PM
We did a compression test, 160-65 across the board. We took the carb out and cleaned it out and put the smallest jets in and it seems to run 90% like it used to.
Have to play with the carb it looks like......
Thanks for everyones help !!
It helps to have a fresh look at things............
