Old 10-05-2007, 02:37 PM
COYBILT's Avatar
COYBILT COYBILT is offline
I just think its nice to see pontiac trans am, not another first gen camaro.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 10-11-2007, 09:36 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
I have always liked the early 2nd gen Trans Ams. This one is going to be awsome .
David
Old 10-28-2007, 01:54 PM
cdoggy81 cdoggy81 is offline
How are we doing on this?
Any updates???
Old 10-28-2007, 07:54 PM
2ndgenracer 2ndgenracer is offline
Default Update
Video of the Hydratech install is up next.
Old 10-28-2007, 11:57 PM
Bandit Ls-1 Bandit Ls-1 is offline
Originally Posted by cdoggy81
Chris,
Is he building a P.T. style 1970 TA? I am too Can I email you for his info?
Bandit Ls-1,
What are you doing with the shaker & the LS-1 on your TA?
cdoggy i havent gotten to that point in my build yet as im doing all the work myself on weekends or when i have free time in the garage but i was thinking of fabing my own "drop base" if its gonna need some more clearance because bolting the shaker to the hood is NOT an option. do u have any info on this?
1979 Trans-Am Ls1 project
1972 Chevelle 454
Old 10-29-2007, 10:44 AM
I'm working on something as well but it will be a while...
PM or email me for info
Old 10-29-2007, 04:24 PM
Default Pictures of how I mounted the shaker scoop
cdoggy81 and Bandit Ls-1,
Thought I'd share how I made my scoop. I was going to bend a piece of sheet metal or aluminum and use it as a base for the carb, but in order to drop it down enough it was going to be in the way of the fogger lines, and it was going to be a bizarre bend, not just a 90 degree bend, but a gradual slope. At this stage I could see bending a half dozen of these before I got it right. So to make life easy, I wanted something that would slide in and out of each other and adjustable. Once I had the scoop where I wanted it in reference to the fogger lines and how far the scoop was sticking out of the hood, I could then just drill through the solid stock and the tube and put a pin in it. Also when I'm at the track I can just pull the four pins and do a quick jet change.
It's not finished yet; I still need to put some black foam or seal around the edge to give it that factory look. I first welded the four alum. solid tubes to some 1/16th sheet then used epoxy to bond it to the fiberglass scoop (Shaker mount). Then to attach those to the motor I used 1/8" plate with alum tube for attaching to the valve cover bolts (Shaker mount 1). I'm sure there are a thousand easier/better ways of doing this, but this might give you some ideas on yours.
Later,
Brett
Old 10-30-2007, 11:10 AM
I'm working on something that will work with the LSx engine & intake requirements.
What do you use for an air cleaner/filter? Looks neat & good thinking!
Old 11-02-2007, 07:41 AM
I'm still finishing the scoop, but I plan on running a K&N panel filter at the back of the scoop, and seal the carb to the scoop with foam. I found that K&N has a killer website where you can search filters by dimension. Punched in the numbers and it came up with three filters, used the cross reference and found the standard filter at the Zone and I'll make sure it will fit with little modification, and then I'll order the K&N.
Old 11-03-2007, 09:58 AM
Smart
Looking forward to seeing some pics!
