Old 10-16-2007, 12:19 PM
Birdman's Avatar
Birdman Birdman is offline
Default Can anyone machine me a few steel plates?
The local machine shop I normally deal with wants $125 for four of these. I know a lot of guys on here have this stuff lying around and can knock it out really quick, so I thought I'd see if someone can help me out.
I need four plates made for the leaf spring hangers on the aftermarket rear frame rails for the Patriot Dream Camaro. I could probably make them at home, but they won't look as clean as I want and I don't have access to a drill press anymore.
They are pretty simple pieces, here is what they need to be:
1998 Trans Am - BMR drop springs, BMR LCA relos, Bilstein shocks, Sportmax 18x9.5 wheels, lots of goodies, 6-spd swap, lQ9 swap
1968 Camaro (Patriot Dream project) - Iron LS1, T56, lowered and nitroused PT machine
PatriotDream.org - Help make a soldier's dream come true
Old 10-16-2007, 12:38 PM
LateNight72 LateNight72 is offline
Check out http://www.cnczone.com
They've got an RFQ section that you can post up on and people will give you quotes, and you can go from there.
I can post it up if you want me to, if you don't want to register and deal with it..
-Todd
Old 10-16-2007, 12:39 PM
68protouring454's Avatar
search for a local water jet place, tell then what your doing, more then likely they have 3/16ths laying around so they could burn a couple out for ya, and with your drawing it would be that much easier
Jake's Rod Shop
Old 10-16-2007, 12:46 PM
Birdman's Avatar
Todd, if you could do that for me it would be great! Maybe someone will hook me up if they know what I'm doing it for.
Good idea on the water jet, too. I sent the local place an email.
Old 10-16-2007, 12:47 PM
CarterHickmanDesigns CarterHickmanDesigns is offline
Try these cats out. I have had several folks use them with great results.
Manufacturing Quote.com
You already have the part drawing just upload it and folks will quote it out.
Carter
Carter Hickman Designs website
Old 10-16-2007, 04:16 PM
coolwelder62's Avatar
How about $50.00 plus shipping. call me Wed. morning 8:30 am ct. at 785.594.7481 Can make them for you thurs. am. and ship thurs. noon. Scott
Old 10-16-2007, 06:53 PM
Bird,
I sent you a PM.
-Todd
