Old 11-07-2007, 02:16 PM
el-camino's Avatar
el-camino el-camino is offline
Default let me see your varishock and spohn setup´s
hi all,
now its all clear. i will buy now the next days from markus the varishock coil overs for the front and spohn lower control arms and a set varishocks for the rear for my camino.
anyone ride with varishocks or spohn ?
i need some input
greets from Sweden
Klaus
Old 11-08-2007, 08:36 AM
el-camino's Avatar
hmm, not only one with varishocks or spohn ? drive all with gabriel ?
greets from Sweden
Klaus
Old 11-14-2007, 02:41 AM
el-camino's Avatar
greets from Sweden
Klaus
Old 11-14-2007, 12:10 PM
slyck68 slyck68 is offline
I'm running the Varishocks on my 68 Firebird, however it is still in the build-up phase and I haven't driven the car yet. They are definitely a top-notch product and seem to adjust very easily. Sorry I can't be more helpful.
Old 11-14-2007, 02:13 PM
el-camino's Avatar
hi,
thanks for your reply.
when you ready, please post your pics
greets from Sweden
Klaus
Old 11-14-2007, 02:47 PM
deuce_454's Avatar
i thought you ordered a set from marcus... lets see your pics..
and while your at it... please post more info on the bmw dash swap.. are you running the bmw heater too??
Jake: Hit it.
Old 11-14-2007, 11:24 PM
el-camino's Avatar
yeep. when i do my setup, i will post the complete story.
my camino becomes a complete new suspension setup, new exhaust, engine modifications and new paint.
the winter is not long enough
yes, when i´m bought 1997 the Camino, the car have no heater, the previus owner remove all the stuff. here some old pics, sorry for the bad quality.
here is a pic from the bmw heater installation
and here the original bmw gauges removed and the autometer in the dash
the dash is not the problem, the most work and modifications i have with the lower center console. the original bmw console is to low and to small, some homemade work.
on this pic on the left side, behind the black plate with the decals is the heater assembly, needs just a small place
greets from Sweden
Klaus
Old 11-15-2007, 09:38 PM
John S John S is offline
OK, you asked for it......
1st, I would strongly recommend that you consider some alternatives to the Spohn lowers. I bought mine from Marcus and had several issues;
  1. They had to be sent back to Spohn to have the mounts widened . They claimed that the delrin bushings were not as forgiving as rubber and that may cause some fitment issues.
  2. mark had to cut off and reweld the sway bar mount because it's position did not allow the sway bar to mount vertically which caused interference with the turn radius.
  3. depending on your Wheel/tire setup the lower mounting plate could scrub the inner surface of your wheels on a full turn.
As far as the varishocks the one thing I will say is do not waste your money on Alstons adjustment tool. It's all but worthless. I cut the handle off of mine and welded an old 3/8" drive socket on it so I could attach a long ratchet to it . Alstons is just too short to do any good on a G body.
Let me also mention that my lowers were originally for standard coil springs and shocks, but I was told they would work fine since there is verly litle difference between them and the coil over design.
Here are some pictures;
Old 11-15-2007, 11:02 PM
el-camino's Avatar
thanks for your detailed and clear statement
i will buy the a-arms they direct for coil overs and hope they fits better than yours.
greets from Sweden
Klaus
Old 11-16-2007, 09:06 AM
Marcus SC&C's Avatar
Hey John,the Monte looks GREAT! Thanks to guys like you Spohn has made a lot of changes and tweaks in the arms. They even make a dedicated Varishock lower for us that`ll work with packages other than your G-5. I`d still like to see a bumpstop on them so folks don`t have to mount one to the frame but that`s about my only issue with them and that`s not a huge one because it`s easily fixed. We do have the new SPC lower arms coming out in the next week or two though. They`re a real step ahead of every other lower arm on the market with improved geometry (we`ve even compensated for centering the wheels in the wheel wells with increased + caster settings),GM bumpstops (ZQ8 are a 2min. bolt in), greasable delrin bushings std.,and they accept either std. coil springs (with laser cut shims to adj. ride height up to +.75" or -.75"!) or coil overs. We`ve been working with SPC on them for almost 2 years now! We brought the cost in at just $514pr. too. They`re going to be THE choice in lower arms. The Spohns will remain a really good (now) budget alternative though.
Klause,awesome BMW dash swap! The small heater box would make things so much nicer on big block cars too. What year/model BMW is it out of?
Mark SC&C
