Old 01-13-2008, 04:11 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
We had to install a pin switch for the trunk but we didn’t want anything visible to detract away from the clean look we are going after. We took a small “micro” switch and built a ABS mounting plate for it so that when the trunk hinge is closed all the way it makes contact, if the trunk opens as little as 1/8″ it will trigger the alarm.
We also started to layup the fiberglass for the subwoofer enclosure/console for between the rear bucket seats.
www.hotrodderjournal.com
Old 01-13-2008, 04:19 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Really Nice Work, Keep me informed. I wonder how hard it it to get a car across the border
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 01-13-2008, 04:20 PM
Easy to sell, easier to have it worked on
Old 01-13-2008, 07:11 PM
vicious69's Avatar
vicious69 vicious69 is offline
Default 1969 camaro console
What type of glue did you use on the modified GTO console? Sweet job!!
Old 01-14-2008, 12:39 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Console looks good,I have an idea of what it takes to make look good,lot of work!
Old 01-14-2008, 04:21 PM
Fluid Power's Avatar
Default Flock
Tim,
What kind of material will you use to 'flock' the inside of the console or the rear door panels?
Darren
Old 01-14-2008, 06:44 PM
Flocking is where you apply a glue to a surface, then "dust" fibers over it till they all stick.
It's the same thing that most older glove boxes were lined with.
Thank you, that means alot coming from you.
Old 01-15-2008, 08:19 PM
We got the Modo Innovations Electric Trunk Release kit installed (see our review of this product)
Got the stereo rack wired and mounted. As we always do, we used molex plugs on the power wires for easy servicing.
Old 01-15-2008, 08:25 PM
bigtyme1's Avatar
where do we see the review? Do you have a different web sight other then you Blog?
69 RS Ragtop
[email protected]
