Old 01-20-2008, 10:16 AM
01somta 01somta is offline
Default Stock subframe damage
I tore down my stock subframe and notice all the oops that have happened to the subframe over the past 40 yrs. I have a couple hairline cracks, which I'm not to worried about. I'll probably just grind a groove in the cracks and then have it welded up. Then only real concern is a pretty big dig/dent in the frame. I was wondering what would be the best way to fix this, what about heating it up and then hammering it back in place? Here are a couple pics of the dig/dent and a couple of the cracks (close up and far away of the cracks).
Dent
Dent
PS crack close up
PS crack far away
DS crack close up
Old 01-20-2008, 10:17 AM
DS crack far away
Old 01-20-2008, 01:16 PM
cetchup's Avatar
cetchup cetchup is offline
Default Subframe damage
The dent is probably the easy fix . It's Always best to straighten a frame
cold, but in this area a little heat won't hurt. The stress cracks are a more serious concern. Before You try to fix them take it to a reputable frame shop
and have it checked for Square, Level,and twist on all planes. Then have a Pro. do the welds. Rearwards of suspension is not an area to learn how to weld on. Looks like it's been on a Baja Run. Good Luck , Jimmy
This one looked like that,but not cracked. http:www.lateral-g.net/members/jjohnson/
Old 01-20-2008, 05:07 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
I'm in the middle of welding my sub frame as well. Do I weld the whole seam from front to back? even over the factor weld or would that be wasting time? or just wear the factory missed?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 01-20-2008, 05:28 PM
68protouring454's Avatar
grind all factory welds to clean them up, then stitch weld frame jumping around so as to not heat one area up to much so it pulls just like body work
Jake's Rod Shop
Old 01-20-2008, 05:36 PM
awr68's Avatar
awr68 awr68 is offline
I had a simular bend/dent as you and just hammer/dollied it back to shape. Then I stitch welded the entire frame....moving all around of course!
Tony
'68 Camaro
Old 01-20-2008, 05:41 PM
bigtyme1's Avatar
Anthony, Throw me some picks. Do I weld the center cross member under the oil pan? I got the internet set up in the garage, this is great.
69 RS Ragtop
[email protected]
