Old 07-19-2005, 09:08 AM
Steve Chryssos's Avatar
Default Universal Shrifter: Ford, Mopar, Etc.
ANNOUNCEMENT: In addition to our direct fit 67-94 GM paddle shifter, we now offer a universal desing that works in conjunction with 3-bolt steering wheel adapters from Grant Products.
For many decades, Grant Products has offered steering wheel adapters that are splined in the center and accept three 1/4-28 bolts in a triangular pattern around that center. These adapters are available for a wide range of applications. So if you have a 67 Mustang, 69 Charger, or a 55 Jeep or even a pre-67 GM car like a 65 Malibu or 57 Chevy, we can now adapt a paddle shifter for your application. Of course, you still need an electronic trans, manumatic ready trans controller, and aftermarket steering wheel 5-bolt, 6 bolt, or 9 bolt steering wheel.
The universal Paddle Shifter design and initial production run are complete. We are now accepting pre-orders. However, orders will be held until field testing is complete--about two weeks. This important step in the process is designed for your safety. Please be patient. If you'd like to get on the waiting list, you will not be charged until date of shipment.
Check out the pix below (which also show-off our new, shorter paddle design.
/Steevo
________________
Steve Chryssos
Ridetech.com
Old 07-19-2005, 11:02 AM
907rs's Avatar
907rs 907rs is offline
Field testing? Sounds like fun. Do you need a new factory test pilot?
Bill
Old 07-20-2005, 09:15 AM
Anytime you wanna come to NY, you are welcome to take a test drive.
/Steevo
________________
Steve Chryssos
Ridetech.com
